capacitor
Rui De pinho
Aug 25, 2021
6
Aug 25, 2021
6
what capacitor is this and what ask for, Please !!
bertus
Nov 8, 2019
3,304
Nov 8, 2019
3,304
Hello
The picture has a lot of grain
The picture does not show any numbers
Are those on the other side ?
Bertus
Rui De pinho
Aug 25, 2021
6
Aug 25, 2021
6
hi all just for info it the violet or purple on top ang grey at the bottom , thanks again ,i cannot make out the numbers
thanks very much to all
Nanren888
Nov 8, 2015
622
Nov 8, 2015
622
For each of the capacitors pictured, there will be a wide range of capacitance values produced in each package.
If you look at
https://www.reichelt.com/at/en/ceramic-capacitors-egpu-c3169.html?&nbc=1
The page up from your link you will see that the pictures for more than one value ar identical.
Noteably, the 1nF and 1pF use the same image. These are a factor of 1,000 different.
Ideally, you would determine which value you need, from markings or circuit schematic and replace with a like value.
