Capacitor voltage values
Discussion in 'Electronic Basics' started by TVisitor, Aug 3, 2008.
  1. TVisitor
    TVisitor Guest
    Let's say I need a cap that's 100uF, 10V.
    Is there any issue with using a Cap with a bigger voltage rating? I
    would think no, it's just the maximum voltage that cap can tolerate
    (and possibly a tad more expensive).
    Thanks.
  2. Eeyore
    Eeyore Guest
    Sure. Use 16V say.
    Graham
  3. TVisitor
    TVisitor Guest
    Thanks John.
  4. neon
    neon
    1,325
    Oct 21, 2006
    don't listen to bad advice a cap volts rating is there for one purpose and one only to give you a safety limit. As a rule stick the biggest that you can afford to install a 2000 mfd and 16v has the same size of a .22 mfd 100v why leakage and reliability. you must use the best cap for your application size and voltage all go together.
