Capacitor value/voltage?
Discussion in 'General Electronics Discussion' started by Steve1M, Jan 28, 2011.
  1. Steve1M
    Steve1M
    3
    Jan 28, 2011
    Folks,
    Wonder if you can help.
    I am struggling to determine the value/voltage of this capacitor.
    Physically, it has 22.5mm leg separation.
    Any info would be much appreciated.
    Many thanks, Steve
  2. rob_croxford
    rob_croxford
    262
    Aug 3, 2010
    Are you 100% its a cap?? Maybe a thick film resistor??
  3. Steve1M
    Steve1M
    3
    Jan 28, 2011
    Rob,
    Thanks for your response.
    It sits in parallel with a 680K resistor, in the mains feed to a relay control board, for a negative head pump that feeds my loft..
    It is labelled "C1" on the PCB position.
    I think "J" may be something to do with tolerance, but all permutations of the other numbers don't seem to match any "standard" cap values/voltages.
    rgds, Steve
  4. rob_croxford
    rob_croxford
    262
    Aug 3, 2010
    Is this the faulty part?? If not you could run some tests to determin its capacitance. However be sure to "discharge" the capacitor using an insulated screwdrive as it may still hold charge.
    Other than that its a tricky one as a preliminary search of the numbers offers little from google. it seems to large to be a smoothing capactitor. what is the voltage of the unit??
  5. Steve1M
    Steve1M
    3
    Jan 28, 2011
    seek and you shall find!!
    Rob,
    Peeled back label....275V 330nF.
    What a plonker!
    Many thanks for your time, Steve
  6. rob_croxford
    rob_croxford
    262
    Aug 3, 2010
    haha ok mate glad you got it sorted!!
