Capacitor value, can you help me?
Discussion in 'Electronic Repair' started by coals, Jun 26, 2007.
  1. coals
    coals Guest
    I disassembled this damaged (I think...) capacitor from my Fluke 87 1°
    series.
    What value is it?
    May be 1µF?
    http://i16.tinypic.com/4lsin39.jpg
    Thank you very much!
    coals
  2. Eeyore
    Eeyore Guest
    Why ?
    Graham
  3. coals
    coals Guest
    Because the Fluke use up battery also in OFF state.
    But now I am not sure that this capacitor is damaged, shoud be only a
    calibration?
    coals
  4. Iain Wilkie
    Iain Wilkie Guest
    Looks like a spark-gap device
  5. JANA
    JANA Guest
    Send your Fluke meter to Fluke service or their rep for proper service. The
    cap may not be the original problem. You cannot calibrate your Fluke meter
    yourself, without their dedicated setup, training, and factory service
    information.
    JANA
    _____
    series.
    What value is it?
    May be 1µF?
    coals
  6. Eeyore
    Eeyore Guest
    I think it is exactly that.
    Graham
  7. Charles
    Charles Guest
    Yes ... perhaps a combined spark-gap/capacitor.
  8. Franc Zabkar
    Franc Zabkar Guest
    http://www.maida.com/content/products/custom/customCom.asp
    "During the early days of the company’s history, Maida developed and
    manufactured custom tubular capacitors and high voltage ceramic
    capacitor stacks for the television industry. Other specialized
    components were later developed such as spark gaps ..."
    - Franc Zabkar
  9. Guest
    Why is that? Is a Weston cell not enough?
    NT
  10. DaveM
    DaveM Guest
    Did removal of the capacitor fix the battery drain problem? If yes then it is
    likely the problem. You should be able to find a replacement from a parts
    vendor, or from Fluke. If not, put it back into the circuit and look elsewhere.
    Are you sure the battery is good? Is it possibly a rechargeable that has
    reached the end of its useful life?
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    "In theory, there isn't any difference between theory and practice. In
    practice, there is." - Yogi Berra
