Capacitor replacement advice
bwspot
Nov 25, 2013
15
Nov 25, 2013
15
I want to replace the capacitor on the power supply board for the samsung tv.
Do the color matter for the capacitors or if i match the value all would be fine?
I noticed there are few 1000uF 25V caps and 2 are dark purple and 1 is dark brown and their height is different, so i wonder if purchasing 3 same 1000uF 25V caps would work or i need the exact colors? See attached for the caps on the board.
ATTACH]10561[/ATTACH]
OLIVE2222
Oct 2, 2011
690
Oct 2, 2011
690
The color doesn't matter, however the temperature range and the ESR does !
better to find out the installed cap datasheet and to buy capacitor with (almost) the same ESR. Also don't buy chinese stuff on Ebay but go for brand like Panasonic on Nichicon at Mouser or Digikey.
Olivier
PS those caps don't look to have a problem, why do you suspect them?
bwspot
Nov 25, 2013
15
Nov 25, 2013
15
Olivier
The tv does not turn on. When i press the power button the power led blinks but tv does not power. 4 of the caps seems to be broken as they have black liquid at the top.
the tv is samsung: Ln26a450c1d and power board is bn44-00208b
OLIVE2222
Oct 2, 2011
690
Oct 2, 2011
690
The black trace are not coming from the caps, they are just marker trace done for any reason at the factory. Cap can have they top "poped" or have visible leak (almost transparent colored) or be dryed (no visible sign).
Electrolytic capacitor is a common failure on TV's, can you post pics of all the power supply caps?
Olivier
bwspot
Nov 25, 2013
15
Nov 25, 2013
15
Olivier
i will do it later once at home.
shrtrnd
Jan 15, 2010
3,876
Jan 15, 2010
3,876
When you replace these caps, check the physical size/lead spacing.
A few times now, I've not paid attention, and bought something that physically
doesn't fit in the old board.
Just something to be aware of.
bwspot
Nov 25, 2013
15
Nov 25, 2013
15
yes i noticed the size is important. For example the board has 3 1000uF 25V caps but they differ in size, but descriptor on the cap itself is same.
OLIVE2222
Oct 2, 2011
690
Oct 2, 2011
690
Capacitors looks OK. Did you check the fuse (located under the code bar)?
Olivier
bwspot
Nov 25, 2013
15
Nov 25, 2013
15
Olivier
checked the fuse and it is ok
i am not an expert but most forums were pointing to capacitors
do they all have to blow to show that they are broken?
can they look normal and still be broken?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
ci am not an expert but most forums were pointing to capacitors
It's a common fault. It's probably worth looking at, even if it doesn't turn out to be the root cause.
No, sometimes they look normal, yet have failed. This is not the common failure mode though.
The real test is with an ESR meter. This will tell you for certain.
Does the output of the power supply do *anything*? Is there a brief pulse of voltage at the output? It is highly unlikely that the power supply could detect failure of the caps without first turning on. It is possible that the power supply could then shut down because it sees some fault condition.
What does the IC labelled as ICM801 have written on it? It is possible that the bootstrap power to this chip (assuming it is the main controller) has failed.
Are there other chips on the other side of the board?
Another fault condition that can cause a power supply to immediately shut down is a failure of one or more rectifiers on the output. This will cause a short overload that can sometimes be heard as a click coming from somewhere on the board before the controller shuts everything down.
Beware that this power supply will have 400VDC on one of the caps and it can kill you when it's plugged in, and give you one hell of a belt even after it has been disconnected from the mains.
bwspot
Nov 25, 2013
15
Nov 25, 2013
15
that seems scarry
is it only the big one or small ones also?
it this is dangerous maybe i should not even try?
OLIVE2222
Oct 2, 2011
690
Oct 2, 2011
690
The capacitors storing the higher voltages are on the Hot side, see indication on PCB and on schematic. You can safely discharge them via a 470 ohms/ 2 watts resistor connected on alligator clips.
The voltage rating written on the capacitor is a good indication of the maximum voltage you can almost expect.
If you are nor comfortable with this repair don't do it or ask to a skilled person to zssist you (HAM, TV repair shop, Electronic club ...)
Olivier
(*steve*)
25,510
25,510
that seems scarry
They're all about the same.
I don't like working with them.
Half or more of them is at mains potential and without some skills with working with them, I'd not attempt trouble-shooting that requires tests while the power is applied.
After the power has been applied, you need to be very careful to ensure you safely discharge the high voltage capacitors, or are *VERY* careful about keeping your fingers away from them.
Being bitten by 400VDC from a capacitor is not something you'll soon forget.
I am somewhat reluctant to offer too much advice because from looking at that circuit diagram, my next step would be to measure a voltage with the power applied (Vcc to the controller).
OLIVE2222
Oct 2, 2011
690
Oct 2, 2011
690
@Steve, I agree that giving remote repairing advice is not advisable here.
However I fill that trashing a TV for few bad caps is bad for the environment (and the wallet). so a "statistical" (according to experience and google results on those TV's) repairing by replacing the caps worth the effort, yes doing measurements on powered TV IS NOT RECOMMENDED as this time is bad for the poster !
@OP you can measure each capacitor with a multimeter in DC position to ensure that they are discharged
Olivier
(*steve*)
25,510
25,510
I agree.
As I said, they're worth looking at.
*carefully*!
Holding both probes in one hand, or otherwise finding a way to only use one hand would be a good idea for the 400V capacitor!
bwspot
Nov 25, 2013
15
Nov 25, 2013
15
I agree.
*carefully*!
capacitors i will be replacing are only 35V max, so i will just test if they are discharged and testing itself should discharge them. Put the board back and turn it on while all is assembled, so i wont be able to touch anything.
