Capacitor I.D. from the 1970's
Discussion in 'Datasheets, Manuals and Component Identification' started by Dancegirl84, Dec 15, 2012.
  1. Dancegirl84
    Dancegirl84
    4
    Dec 15, 2012
    Can anyone i.d. this capacitor from a 1970's turntable:
    [​IMG]
    MP Capacitor
    M15AML605U
    6 uF
    150WV A.C.
    01 theta symbol
    I am trying to find a suitable replacement :(
  2. shrtrnd
    shrtrnd
    3,783
    499
    Jan 15, 2010
    I don't know the manufacturer off the top of my head, they're probably not in business
    anymore. But what you have is a 6 microfarad, 150VAC electrolytic can with what are
    probably radial leads. It won't be hard to find an equivalent.
  3. Dancegirl84
    Dancegirl84
    4
    Dec 15, 2012
    Any idea where from?
  4. davenn
    davenn Moderator
    13,722
    1,913
    any electronics parts supplier
    digikey, mouser, element14, RS components, maybe even Rat Shack if they still have components
  5. Raven Luni
    Raven Luni
    798
    8
    Oct 15, 2011
    The MP could stand for metalised polypropylene. I've never seen one in a metal can though.
  6. (*steve*)
    25,449
    2,809
    The replacement part is likely to be far smaller, possibly brightly coloured, and overall totally dissimilar in appearance.
    If you want to retain a "vintage" appearance, take the old device and remove the innards, and place the new capacitor inside the old housing.
    (Another question is "why do you think it has failed", but I'll presume that you are certain of it)
  7. Dancegirl84
    Dancegirl84
    4
    Dec 15, 2012
    Thank you for the replies, the capacitor hasn't stopped working but after almost 40 years I thought it might be prudent to replace all the components involved with feeding the motor; a small PCB with one resitor, one fuse and one capacitor plus this can capacitor directly inline to the motor.
    Fuse = 500mA
    Resistor = brown colour, 1 = yellow, 2 = purple, 3 = gold and 4 = silver
    PCB Cap = 0,047uF 250v MP
    and this large can capacitor.
    The motor is 4 pole synchronous.
  8. Raven Luni
    Raven Luni
    798
    8
    Oct 15, 2011
    The resistor is 4.7 ohms with a +/-10% tolerance. Given the low value and the fact that the voltage across it is unknown, make sure to choose a replacement rated for at least a few watts A standard 1/4W resistor will likely give you rice crispies (snap crackle and pop).
  9. Dancegirl84
    Dancegirl84
    4
    Dec 15, 2012
    I have searched all of the electronic component suppliers mentioned and none of them have a 6uF 150vAC capacitor of any kind :confused:. Am I reading the letters correctly on the side of this capacitor?
  10. davenn
    davenn Moderator
    13,722
    1,913
    a 4.7 uF will be close enough, those styles of caps generally have broad tolerance ranges
  11. davidcr85
    davidcr85
    3
    Dec 30, 2012
    MP= Motor Power capacitor.
    This site can help you find a solution
    http://www.antiqueradios.com/forums/viewtopic.php?f=19&t=198223
  12. tedstruk
    tedstruk
    475
    7
    Jan 7, 2012
    this must be motor start capacitor. motor start caps that are 110v, are often rated at 150v. I would assume the 6microfarad mark to be just that 110v 6uf cap for motor start. <deleted bad info>
