Capacitor Help Needed....Picture Link Included
Discussion in 'Electronic Repair' started by Deejay, Mar 7, 2006.
  1. Deejay
    Deejay Guest
    Can someone please help me identify the capacitor in the link below? I
    don't really understand the writing on the capacitor so I'm having a
    super hard time trying to find a replacement. All I know is that it is
    not working and I need to solder a new one back on to the device in
    which I took it off to get it to work again. Please help....thanks.
    http://home.pacbell.net/deejay27/capacitor_pic.jpg
  2. Ray L. Volts
    Ray L. Volts Guest
    Metallized polyester film
    ..1 microfarad
    10% tolerance (K)
    630 Volt rated
    MKT polys are typically higher-temp, higher-accuracy than the garden variety
    "green caps"; they're commonly found in high-end audio..
  3. Ross Herbert
    Ross Herbert Guest
    You didn't leave the pic there for long did you? If you got the answer
    you were after then post a reply saying so and that you are removing
    the link.
