capacitor failure mode etc ?
Discussion in 'Electronic Repair' started by N_Cook, Dec 20, 2012.
  1. N_Cook
    N_Cook Guest
    2x 250V , 2.2uF yellow epoxy sealed polyester? caps used as intermediary
    high DC storage in an electric fence unit. Failed as one of these caps is
    fairly consistently ohmic at 370 ohm.
    Now repaired 195V dc over them ,peak. Used in the wettest part of the UK ,
    Cumbria, so assumed due to condensation getting inside the cap, no direct
    rain ingress traces seen.
    But removing the cap casing and pulling back the leads , no trace of
    green/corrossion. Heating , with low heat of a hot air gun , ohms drop to
    350 and then back up again on cooling.
    Failure due to damp or HV punch through? .
    This is PbF solder but is RoHS a consideration inside such caps , ie
    dendrite formation? If punch through then does the oscillator need knocking
    back a bit, 2 presets on the board. Replaced both of these caps and another
    one used in the pulse shaping drive to the "pulse Tx" , the usual backwards
    mains Tx. Thinking perhaps if unit is in direct sunlight perhaps the pump
    circuit gives out 300V say. Schematic not seen but HV zeners in that area
    270V + 16V plus another , voltage not seen but probably 16V.
    I was inclined to drop the value of the 270V one but I assume these are
    fudge values, "selected on test" for nA leakage at less than combined knee
    voltage of about 300V and has been working for 5 years , then presumably ok
    to leave as is , as these zeners DVM diode test at least as normal.
  2. nesesu
    nesesu Guest
    As you say, there are several factors involved here. Indeed it could be moisture ingress or it could be punch through. The punch through could be froma spike or just a weak point in the dielectric that failed under long termstress somewhat below rating. Since this is in a fence charger I would also consider lightning. I have repaired a couple of fence chargers that suffered from induced transients from nearby lightning, and in both cases the caps had failed to high leakage. One unit was an electromechanical type wherethe cap across the points had gone leaky, the other was similar to what you have and the storage cap was blown.
    Neil S.
  3. N_Cook
    N_Cook Guest
    fairly consistently ohmic at 370 ohm. Now repaired 195V dc over them ,peak.
    Used in the wettest part of the UK , Cumbria, so assumed due to condensation
    getting inside the cap, no direct rain ingress traces seen. But removing the
    cap casing and pulling back the leads , no trace of green/corrossion.
    Heating , with low heat of a hot air gun , ohms drop to 350 and then back up
    again on cooling. Failure due to damp or HV punch through? . This is PbF
    solder but is RoHS a consideration inside such caps , ie dendrite formation?
    If punch through then does the oscillator need knocking back a bit, 2
    presets on the board. Replaced both of these caps and another one used in
    the pulse shaping drive to the "pulse Tx" , the usual backwards mains Tx.
    Thinking perhaps if unit is in direct sunlight perhaps the pump circuit
    gives out 300V say. Schematic not seen but HV zeners in that area 270V + 16V
    plus another , voltage not seen but probably 16V. I was inclined to drop the
    value of the 270V one but I assume these are fudge values, "selected on
    test" for nA leakage at less than combined knee voltage of about 300V and
    has been working for 5 years , then presumably ok to leave as is , as these
    from a spike or just a weak point in the dielectric that failed under long
    term stress somewhat below rating. Since this is in a fence charger I would
    where the cap across the points had gone leaky, the other was similar to
    Neil S.
    I've come across a near lightning struck one before and it knocked out a
    custom PIC/ASIC with no work around. I would gave expected that more likely
    than high V caps failing from spikes. This 2006 made unit oddly could have
    be made in 1976 all discrete , assuming a Programmable Unijunction Transitor
    for the SCR was available in 1976 . I had asked the owner about lightning
    in area and he reckoned not.
    I wonder what other test to determine if punch through or metalisation
    creep/dendrite ? only for professional interest reasons, I'm reasonably
    content to return, as is , without any mods. As lightning is "act of God"
    cannot sensibly mitigate against that. One advantage of old circuits -
    nearly always repeairable
  4. Guest
    Lead free solder should have nothing to do with hermetic sealing really, unless you are talking the tinning of the leads. Even that is pretty far fetched I think. The tinning is very thin and the thermal expansion coeffeicient of the base wire underneath should be the major factor.
    If you want my highly respected carefully considered professional opinion -I think the cheap ass thing just went bad.
  5. Guest
    "Unijunction Transitor
    for the SCR was available in 1976"
    Oh definitely. I think every Tektronix manual since about 1965 had a tutorial on them. (and I STILL coudn't design a circuit using one they are too wierd lol) Actually UJT triggering was one of the things about good scopes, they would lock up really fast. I had a 2465 for a time and it's sync sucked.. I mean it DID actually sync, but it took too damn long. I was spoiled by older scopes that would lock up faster than the shutdown could shut down the TV. I could cop a collector waveform off the HOT (or LOT for you over there) fast enogh to see it, and then start unconnecting things. It was quite useful.
    Years ago there was a time when if I didn't have a shutdown problem figuredout in about five minutes, scrapping the set was considered. I had my routine and it worked. I'm now working on a new routine of course.
    Of couirse it is all useless knowledge now. I feel like a fucking trainee now.
  6. N_Cook
    N_Cook Guest
    I've started unwinding this and it would seem to be wide scale
    electrochemical breakdown. Each turn I unwind the ohmage goes up each time I
    measure it, now 700 ohms or so. The unwound film looks like a piece of 35 mm
    projection film of white image and no sprocket holes. Milky clear patches,
    not clear polyester, between "silvering" that is wavy at the edges,
    periodicity of the half the length per turn, and a repeat strip like 35 mm
    film strip, twice per turn. The silvering of each large flat face seems to
    have disappeared leaving it at the tight bends, twice per turn
    Of course I don't know what it should look like and will have to break into
    a new, different make one, to check and also one of the other 2 of the same
    batch as the failed one , both measure near enough 2.2uF.
    And try taking pics of it all
  7. N_Cook
    N_Cook Guest
    Here is a pic.
    http://www.diverse.4mg.com/duff_cap.jpg
    The leftmost is the bad cap, centre an older but unused Philips also 2.2uF
    250V, and the third is from the same batch as the bad, not ohmic up to
    30Mohm anyway
    The 2 red >s are "frames" 10&11 that show the curving and the graph paper
    behind where all the "silvering" is absent, so film colours consist of
    silver, grey colour , hazy white and clear .
    Centre is good "silver" and crystal clear polyester , only colours, with
    alternate gutters for the edge connection, metal lead masses retained so
    ragged edges from my unwinding.
    Right one shows the same effect on the outer 4 frames but beyond that the
    metal foil is entire, but going home as the other.
    Yellow case is the bad TC make and blue is 3 sides of the Philips puter
    case. The philips actual capacitor volume is much less than the TC so epoxy
    filling , inside the block casing is complete, but both the others you can
    see the active film in a number of places , after removing the block plastic
    casing. This epoxy? inner encapsulation was much easier to break away than
    the Philips. I suspect the Philips used 100% epoxy and the TC had fillered
    epoxy so maybe making porous. No green corrossion products seen but I assume
    capillary migration of condensation through the poor epoxy from the open end
    with the leads or along the leads which were bright shiney in all of them.
    So this will be a generic fault with Electric Shepherd ESB55 , first
    becoming apparent in the wettest county of Cumberland in 5 years of use and
    then other counties later presumably
  8. I can't tell anything from the tiny photo, but a lack of metallization
    sounds like the cap had the elctrodes burn from constant overvoltage or
    breakdown/overload/ With such a low resistance, it may not be possible to
    measure
    the actual capacitance of the bad caps. It will drop as "self healing"
    caps start to wear out. Something around 5% loss is considered end of life
    for many applications.
    Are you able to burn test the dielectric to see what it really is?
  9. N_Cook
    N_Cook Guest
    I'm assuming, although no water trails seen, that it starts with capilliary
    action bringing dampness between the outer casing and the capacitor proper
    as in Philips and TC the epoxy fill does not bond to the outer case , it
    pulls away easily.
    Then something to do with the 200V, perhaps the curving edges , maximum
    width at the middle of the flat faces is something to do with charge
    distribution. As powdered aluminium is grey I'm assuming the grey colour of
    the depleted metal is finely divided Al and the white is Aluminium oxide.
    So you reckon millions of point discharges have erroded away the metal ?
    sounds logical but would not the plastic show signs of roughening, I will
    have a look under a microscope. The discharges have to be through the
    plastic, would dampness enhance that, considering the effect starts at the
    outer layers , not the inner, it would seem
    I would not know what to smell for / test for, with burning
    or do you mean melting and then
    The melting point of HDPE (High Density Polyethelyne) is about 130 ºC
    The melting point of LDPE (Low Density Polyethelyne) is about 110 ºC
    The melting point of PET (Polyethylene terphthalate) is about 250-260 ºC
    The melting point of PP (Polypropylene) is about 160-170 ºC
    The melting point of PS (Polystyrene) is about 70-115 ºC
    The melting point of PVC (Polyvinyl Chloride) is about 75-90 ºC
  10. N_Cook
    N_Cook Guest
    by burn test , this sort of discrimination?
    http://www.boedeker.com/burntest.htm
  11. N_Cook
    N_Cook Guest
    Along the way I seem to have misinterpreted the meaning of "self-healing" as
    the plastic is punctured and then melts to reseal. But seemingly it is the
    aluminium that "spark erodes" away to something, what material ? and then
    cannot discharge to that point again and termed healing.
    Via microscope lots of random tiny holes in the aluminium in the bad
    sections, no holes seen in the plastic.
    Next thing is to identify the insulator film as I assume some plastics are
    porous or whatever the term is under the presence of water/water vapour to
    reduce the electrostatic breakdown potential.
  12. N_Cook
    N_Cook Guest
    revised pic on that URL
    the Philips 373 MKT was polyester as was the yellow TC probably, by that
    flame test.
    Yellow flame , sustained after flame removal, no drips, slow
    progress,brittle remains, although HCl not smelled.
    This film 15 microns, WVTR permeability of 25 micron films in g/m^2/day
    polyester 4
    Polythene 20
    Polycarbonate 170, I didn;t realise this was so "porous"
    From the boating industry epoxy has much better permeability figure than
    polyester.
    Now just to find the quantative deleterious effect of water/vapour on
    dielectric strength.
  13. polyster is cheap, so that's usually what you'll come across first for a
    DC capacitor.
    Tape and fill caps aren't considered hermetically sealed. If you want
    that you need a metal can, but those cost more money, so moisture ingress
    isn't really too surprising- if that's the problem.
    in the self healing caps, once the dielecric punches though, the super
    thin aluminum coating burns up like a fuse, isolating that are with the
    pinhole though the plastic. Everytime this happens, you lose more and more
    plate area and capacitance drops.
    the low resistance reading is strange though. Even damp nylon probably
    won't conduct at much, and it really lik to absorb water.
  14. you can do that or see how the film melts, tears or handles stretching
    (changes color etc).
    A DC filter-ish cap would likely be polyester, but they have other
    plastics now these days in addition to the plain old polycarbonate and
    polypropylene. Polystyrene caps are no longer made last I heard.
