Capacitor discharge probes
Discussion in 'Electronic Basics' started by Shaun, Jun 18, 2010.
  1. Shaun
    Shaun Guest
    Hello,
    I recently bought a Blue ESR meter and assembled it and it is working well.
    In the instructions it mentions making a jig with a 100 ohm 5 watt resistor
    attached to some probes for discharging capacitors before testing them with
    the ESR meter.
    How does one calculate the required resistor wattage for different capacitor
    values. Say I wanted to discharge a 63 volt cap at 500 microfarads, would 5
    watts be enough. Right now I've made a probe jig with four 100 ohm 3 watt
    resistors for a total of 100 ohms at 12 watts.
    thanks in advance,
    Shaun
  2. Tom Biasi
    Tom Biasi Guest
    Hi Shaun,
    I could say a few words here but Sam can provide you with much more info.
    See here: http://www.repairfaq.org/sam/captest.htm
    Tom
  3. Shaun
    Shaun Guest
    Thanks for the link, there is alot of information there but not what I was
    asking for.
    How do you calculate resistor power rating required to discharge a capacitor
    of x volts and y microfarads?
    Shaun
  4. Phil Allison
    Phil Allison Guest
    "Shaun"
    ** You are labouring under a mis-apprehension.
    Any resistor connected across a capacitors will EVENTUALLY discharge it.
    The only things to worry abut are how long will it take and might the
    resistor become damaged by too much current .
    A 100 ohm, 5W *wire wound* resistor will discharge almost any electro ( to a
    safe voltage) in no more than a few seconds - however a very large, high
    voltage electro might have enough energy to destroy it.
    ..... Phil
  5. Phil Allison
    Phil Allison Guest
    The vast majority of capacitors will be discharged by the time you get
    your test probes ready to use. I've been doing ESR stuff several years
    and only once did I damage a meter by sending power into a Capacitor
    Wizard. It was a small value (around 10 ohms) resistor that fried and
    only took a few minutes to replace. Or do you just want formulas?
    ** The " Blue ESR Meter " will be damaged by voltages more than about 50
    volts DC
    http://members.ozemail.com.au/~bobpar/esrmeter.htm
    ...... Phil
  6. oo pere oo
    oo pere oo Guest
    A 1K resistor will discharge a 1000uF capacitor in 5s.
    A 100R resistor achieves the same in 0.5s.
    Time constant is tau=R·C and in 4 or 5 tau you have discharged your
    capacitor.
    The power absorbed by the resistor at the moment of closing the circuit
    is V²/R. For V=63V and R=100R, this is roughly 40W. At t=0.1s voltage is
    just 23V and instantaneous power absorbed 5W. Your jig will certainly
    survive such short spikes. If you take 1K, a single resistor will
    achieve the same at the cost of some extra time :)
    Pere
  7. Phil Allison
    Phil Allison Guest
    "oo pere oo"
    ** All perfectly correct.
    However, a physically small resistor can only absorb so much energy in a
    short space of time before the conductor inside MELTS !!
    The energy stored in a capacitor is give by the formula:
    E = 0.5C x V squared.
    Taking a practical, worst case example of a 1000uF cap charged to 400
    volts - the stored energy is 80 joules, most of which is dumped in the
    first 0.2 seconds.
    Depends very much on the construction of the particular resistor whether it
    can absorb such a large energy spike or not.
    The best type is carbon composition, then wire wound and last of all
    deposited film resistors.
    ..... Phil
  8. oo pere oo
    oo pere oo Guest
    Just made a quick search on some Farnell 100R resistors. It is
    interesting to see that a 1W CCR resistor such as CCR1100RKTB (Tyco) has
    a pulse limiting power of 600W for single 0.1s pulses.
    Pere
  9. amdx
    amdx Guest
    Did we all just witness a lovefest from Phil? :)
    Mike
  10. Shaun
    Shaun Guest
    Thanks for all your replies.
    So I guess the important factor is it's pulse power rating for a resistor,
    although I haven't seen any resistors with this spec before. If I work out
    the math now that I know what to do thanks to you guys, P = 1/10 V^2/R
    for 5 tau. What confuses me is that C cancels out, so it wouldn't matter
    what value of C I'm discharging, the only thing that changes is the amount
    of time it takes to discharge.
    Does anyone know a rule of thumb for pulse power verses continuous power for
    a given time frame for a resistor??
    thanks again,
    Shaun
  11. be careful with that.
    50J exploded 20 guage magnet wire like a fuse and blew a piece into my
    hand once.
    I wasn't expecting that to happen at all.
