capacitive load on triacs
Discussion in 'Electronic Design' started by raseel, Apr 23, 2005.
  1. raseel
    raseel Guest
    hai,
    iam designed a triac circuit to controll a capacitive load. The triac
    used is BT139. I am not included a snubber circuit.Is that necessory
    for capactive load??
    Then how is the design the snubber components?? iam expecting a
    positive reply..
    RASEEL
  2. Robert Baer
    Robert Baer Guest
    "Snubber" circuite are used when inductors are being switched, due to
    the ringing / high voltages created by inductors (dI/dT).
    So.. look at a circuit like the following: power supply feeds a
    resistor to a switch to ground (the triac) and the capacitor is in
    parallel with the switch.
    Start with switch open - capacitor charges to supply voltage = is
    triac rated for that voltage (or more)?
    Then close the switch (turn on triac) - large current flows from
    capacitor thru triac, limited only by inherent resistances of the
    circuit = is the I*I*T rating of the triac exceeded (pronounced "eye
    squared tee")?
    Sadly that data appears to be very absent these days; 30-40 years ago
    that crucial design info was *published* as a part of the data sheet
    specification of (power) thyratrons, ignitrons, SCRs and triacs.
    That info is similar to SOAR or Safe Operating Area in power
    transistors and is absolutely necessary so that a designer can prevent
    device destruction.
  3. The dI/dt rating is more likely to be important if a capacitive
    load is being switched. An inductive load tends to be a
    gentle one with respect to dI/dt since inductor current is
    hard to change fast.
    (To the OP:)
    You need to be sure that something limits the rate at which
    current rises when the triac is first turned on. Until it has
    been fully turned on, it can be harmed by currents that are
    well within the device current rating. Inductance is often
    added in the load circuit to limit dI/dt to the device rating.
    For your BT139, that is 10 to 50 A/uS depending on the
    load current direction and the gate drive polarity.
    (Cut the rest, with which I agree.)
  4. Alan Turner
    Alan Turner Guest
    Hi
    Perhaps it may be possible to fire the triac near the zero crossing of the
    mains voltage. In this case the current will be limited to C*dv/dt. This
    assumes that the initial charge on the cap is zero of course :)
    I suppose it depends if the OP wants an "on-off" control, or one with a
    variable firing angle. If it is an on-off situation, the OP might consider
    a solid state relay.
    Regards,
    Alan
  5. Fred Bloggs
    Fred Bloggs Guest
    Another example of Brasfield moronic advice. Hey , Larry, you try hard
    to be the big anal-yst but it's not working too well for you- you just
    don't have the evolutionary endowment. To listen to a moron like you one
    would suspect that a 50A/us current rise limiting at 1mA would blow the
    thyristor...what a confounded idiot and fake you are. It looks like you
    are a total failure at actually understanding anything. All you know how
    to do is regurgitate specs you can't fathom- pathetic.
  6. Derf transform applied.
    Your "1mA" figure has no factual basis in this thread.
    My advice to the OP could easily be pertinent.
  7. Fred Bloggs
    Fred Bloggs Guest
    Larry Brasfield wrote:
    [...snip moron Brasfield editing...]
    You are running 10/10 on worthless and inapplicable "advice" so far.
    Keep using your little specious pseudo-intellectual vocabulary- just
    love it- a sure sign of a nobody trying to be a somebody the way you
    misuse those words. You are a good-for-nothing loser. You should find
    companionship with a certain sub-population of similarly worthless
    trolls on SED- lots of non-degreed technician types here- long on OT
    opinions and sickeningly short on anything worthwhile or constructive.
  8. Larry Brasfield wrote...
    A bit misleading in the OP's case. The di/dt issue addresses the
    case of repetitive low-gate di/dt drive while expecting fast triac
    current rise. This involves conduction-spreading, an issue that's
    reduced with more aggressive gate drive. Usually a more relevant
    issue arising from high peak currents when switching capacitive
    loads is the need to model the transient power dissipation, and
    analyze this against the "Transient thermal impedance" curves.
    This reveals the triac's transient thermal mass, which must absorb
    the transient energy without exceeding Philips' modest 125C maximum
    junction-temp spec for the BT139. As with the dI/dt issue, adding
    series inductance is sometimes helpful because the part's available
    thermal mass increases by the square root of the increased duration
    of the heat pulse.
  9. Mr. Baer's post to which I was responding adequately mentioned
    the pulse energy issue. I don't think it is misleading for me to add
    another consideration, especially when I indicated agreement with
    the rest of Mr. Baer's advice, including that issue.
    Have you seen any data on how safe dI/dt varies with gate drive?
    My understanding is that the gate does not reach all portions of the
    junction pair that is being turned on and that conduction spreading
    is what gets most of the device area conducting. Given the relative
    magnitude of the load and gate currents, at least when dI/dt is an
    issue, I would expect the spreading rate to be independent of the
    initial gate drive.
  10. Robert Baer
    Robert Baer Guest
    I can see that one might think that dI/dT is important, but I*I*T is
    far more important!
    If you check out the units, (I*I*T)*R ==> energy (aka power).
    And it is a high amount of power that can literally vaporize devices.
  11. Larry Brasfield wrote...
    If you study various manufacturer's writings on the issue, you'll
    learn that high-current fast-risetime gate drive is important in
    high dI/dt applications. I haven't made comparative measurements
    myself, but I've read enough to give me respect for the argument.
  12. Fred Bloggs
    Fred Bloggs Guest
    Hey, idiot- this is your standard cop-out: first you pretend to post an
    all encompassing description and then you later claim some mousy excuse
    whenever anyone points out your omissions. Looks like you have a pat set
    of excuses on the ready- along with the "I have nothing to prove"
    weaseling- you are a worthless usenet troll and snake who gets whacked
    early every time.
    Think it might be a diffusion capacitance charging issue, retard? Your
    confusion here does not gel with your claimed prowess in that eb-zener
    "puzzle" you were pseudo-intellectualizing over earlier. It is a very
    sorry situation when a person your age insists on living in a fantasy
    land when you should be reconciling your ignorance, incompetence, and
    overall worthlessness as a human being. Go away and stay away.
  13. [Derf transform applied.]
    False. My first post on this thread raised a single issue without
    making any claims that other issues did not exist or matter. To
    the contrary, I acknowledged the existence and relevance of other
    issues with my quoting note: "(Cut the rest, with which I agree.)"
    Many people consider the excision of material irrelevant to the
    points being made to be good Usenet practise, as do I. Your
    transformation of it into an excuse for spew is pathetic.
    [derf]
    I doubt it for reasons I doubt you could discuss intelligently.
    However, the notion of charging the diffusion capacitance
    is rather amusing. Do you think it exists before "charging"?
    [derf]
    Your obsessive repetition is fascinating. Again, No.
  14. Fred Bloggs
    Fred Bloggs Guest
    Ehhh- shut the F__K up, you whining little fake- looks like you're
    drowning, poser, get a clue.
    You have this persistent hang-up on intelligence because you do not
    possess any- tough sh_t pseudo-intellectual, you will just have to work
    with the hand God dealt you, and that "ain't" much...
    Carry on, little trooper, just like your mommy and daddy taught
    you...you're essentially a little weakling loudmouth and a wet rag as an
    engineer poser...and guess what?- mommy and daddy were wrong- you are
    truly a p.o. crap...
  15. Ken Smith
    Ken Smith Guest
    In crowbar applications, the worst capacitive load case, the gate drive
    really should have a rise time under 100nS. You want to hit the part with
    nearly the makers limit for gate current.
    Also, the inductance decreases the energy that has to be eaten in the SCR.
    A small impedance prevents the current from rising to a huge number until
    after the voltage on the SCR is decreased. The inductor doesn't even have
    to remain an inductor at the full current. An inductor that is lossy to
    high frequencies and saturates as the full current seems to work fairly
    well to keep an SCR alive. I've used a 0.25 inch toroid of 3F3(I think
    from memeory) material with a few turns of #14 wire. The current waveform
    looked something like this:
    ^ Way up off screen
    ! on the scope
    I think what happens is that the lossiness of the inductor lets an initial
    current flow because the loss makes it look like a parallel RL circuit.
    This initial current gives the SCR a chance to have its morning coffee
    before it needs to do any real work.
