Capacitance Meter ????
Discussion in 'Beginner Electronics' started by Jim Simmons, Jun 17, 2004.
  1. Jim Simmons
    Jim Simmons Guest
    Looking for any kind of information about a kit constructed printed circuit
    board with the following info on it DAGE CM-334. very well made design.
    Circuit board mounts everything except power supply and is mounted using
    the select switch and the zero adjust. Kit is very well made excellent
    components. Has a older 3 digit readout in the upper left section of the
    board, the zero adjust is in the upper right, and just below it is the
    selection switch. Selection switch position are; OFF, mF, and uF.
    Thanks!
    Jim
