cap charging batteries
Discussion in 'Home Power and Microgeneration' started by Peterthinking, Sep 11, 2003.
  1. I want to have a small wind turbine on my roof.
    the wind here is pretty mellow but steady.
    I want to store the energy in a capacitor and when it's full let it loose
    into the batteries with higher amps and volts.
    like a beam robot
    http://www.solarbotics.com/beam/default.asp
    it'd charge intermittently but at a useful level of amperage and voltage.
    any plans for such a thing that anyone here knows of?
    perhaps a kit?
    Peter
  2. Ian Stirling
    Ian Stirling Guest
    Why?
    For simply charging them, this is worse than constant current.
    http://inquisitor.i.am/ | mailto: | Ian Stirling.
    He had been eight years upon a project for extracting sunbeams out of cucumbers,
    which were to be put in vials hermetically sealed, and let out to warm the air
    in raw inclement summers. -- Jonathan Swift, "Gulliver's Travels" (1726)
  3. I don't expect very much output
    doesn't the voltage going in have to be greater than the voltage of the
    battery?
  4. Ian Stirling
    Ian Stirling Guest
    <snip quoted message incorrectly placed at bottom>
    Yes.
    But if you have some means to charge the capacitor to a higher voltage
    before discharging it into the battery, you'r almost always better just
    using it to charge the battery.
