Can't figure out capacitor value
Discussion in 'Datasheets, Manuals and Component Identification' started by boogyman19946, Dec 15, 2011.
  1. boogyman19946
    boogyman19946
    38
    May 2, 2011
    Ok, I have a few capacitors for which value I can't quite understand. The other ones that I was checking we're fairly straightforward but these don't seem to be orthodox.
    A few of them have a number that's prefixed with a period and a few numbers after it. They are:
    .033J
    .022J
    .001J
    The .022J has 100HT written below it, but I'm not sure if the others one do so too. If needed, I can find out.
    and another one has 331. written on it. The first 3 are green and the 331. one looks like a ceramic one.
    Does anyone have an idea what the values of these capacitors are?
    EDIT: I think I figured out the .xxxJ capacitors. I found a website that says .022J would evaluate to 200pf with 5% tolerance, but I'm boggled why it wasn't named 201J instead, and why the period is there. Also, this doesn't work for .001J because it would mean it's a 0pf capacitor XD
  2. davelectronic
    davelectronic
    1,087
    12
    Dec 13, 2010
  3. duke37
    duke37
    5,297
    739
    Jan 9, 2011
    I would guess that the .022J capacitor is 0.022microF i.e. 22nF. (A preferred value)
    The J is probably the dielectric.
    The 331 is the value in pF as marked on resistors (3 3 and one 0) so 330pF. Somewhat confusing!
  4. Harald Kapp
    9,646
    2,014
  5. boogyman19946
    boogyman19946
    38
    May 2, 2011
    I'll try those values duke, we'll see if they work
    @Harald, thanks for the article! It's much more detailed than the one I read.
  6. davenn
    davenn Moderator
    13,496
    1,830
    The "J" is the tolerance in this case 5%
    G = 2%, K = 10% L = 15%, N = 30%
    J, K and L are the common ones you will see.
    .001J is .001 uF (microFarad) = 10nF (nanoFarad) @ 5% tolerance
    Thats incorrect, this is correct -----> .022 = .022uF = 22nF = 22,000pF
    cheers
  7. boogyman19946
    boogyman19946
    38
    May 2, 2011
    @dave, I'm not sure how the numbers are supposed to be decoded still. I'm getting that they're read as the direct value in nanoFarads but you wrote that .001J should be 10nf. Shouldn't that be 1nf if .022J is 22nf?
  8. (*steve*)
    25,298
    2,736
    Correct, 0.001uF = 1nF
