have never seen the PS go on one of these before. Did you check the fuse?
Usually if you see alot of Toner in there esp on the Corona, it means it
really needs a good complete internal cleaning. Try Air in a Can to blast
out the loose toner, but do not breathe any of it in.
If still nothing , try posting here, its a very helpful board:
http://www.smarka.com/
| Thanks for your suggestion. I just carefully cleaned the corona wire
| on the copier bed. Removed a lot of toner from the shiny metal trough
| and made sure there was no toner on the wire. I than ran the cleaner
| brush through the cartridge. Still nothing at all appearing on the
| paper. I'm still suspecting the HV. Is there an easy way to test
| the supply?
| Bob
| > Check the Corona Wire, it has a habit of getting dirty full of toner,
and if
| > that happens usually it wont transfer the image.
| > | > | I've had this copier for a number of years but this summer when the
| > | humidity was high it took several passes through to get a decent copy.
| > | Now the air is dryer but it won't copy at all. I'm wondering if
| > | there is a HV supply that is dead? Is anyone familiar with this
| > | machine?
| > | Bob
