Canon Optura repair advice?
Discussion in 'Electronic Repair' started by gothika, Feb 25, 2004.
  1. gothika
    gothika Guest
    I've got a Canon Optura dv camera that is dead.
    I'm sure it's a result of improper power polarity.
    I used an aftermarket battery pack and reversed the polarity.
    This usually results in burning out whatever is first in line in hte
    power path.(power cap, fuse diode etc...)
    I don't have any working experience with these consumer cameras and
    thought it best to ask here before I open this unit up.
    Does anyone here have any experience/knowledge in servicing this
    problem in these units?
    As always any info is appreciated.
  2. Jerry G.
    Jerry G. Guest
    This is something that is commonly done by many people who think they can
    save a few dollars. I have seen some expensive damage done by people trying
    their own battery substitution. Sometimes you can be lucky, and only an
    internal fuse or fuse resistor of some type is blown. Sometimes it can be
    only the inverter board on the main power input side of the unit. If some
    of the main processing circuits are run directly from the input voltage,
    then the problem can be more serious.
    You have to go to a Canon authorized service rep with this. Only if it is a
    simple problem like a fuse or generic component that can be easily
    determined, that the independent would be able to service himself. Canon
    does not normally release service information, or sell internal parts to
    non-authorized for Canon service people.
    If you call Canon in your area, they can refer you to their authorized
    service.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
  3. Ken Weitzel
    Ken Weitzel Guest
    Hi...
    No experience at all with Canon's, so can't help at all
    there. Sorry.
    I do however play a lot with Olympus's and wanted to throw
    in my quick little suggestion, if I may?
    If you do take it apart, be very very scared of that
    flash cap. Bad news. I'd rather hold on to a flyback
    than come into contact with that thing! :)
    Take care.
    Ken
    PS
    Not the first "thing" in the path, but rather the
    weakest "link" in the entire chain.
  4. gothika
    gothika Guest
    Thanks for replying anyway.
    You're most certainly right about weakest link.
    I've had this happen on my eng/broadcast field units years ago and
    in most cases it'd be a diode or the first cap off the power feed.
    This has gotten my thinking in a fixed rut inregards to this type of
    breakdown. I often forget how consumer gear is often designed poorly
    or deliberately to go south easily.(Miss the early days when most
    cameras had circuit breaker protection.)
    I'm often more leery about going into consumer than I am pro gear.
    If I don't get any answers here I may just opt to give it to a local
    video repairman I know, he's got tons more experience on these smaller
    cameras.
  5. gothika
    gothika Guest
    Thanks for the reply Jerry. Yes your right this is a common mishap.
    I shoot professionally and have to hire many shooters to cover an
    event.
    I had several packs I'd built for this camera that worked fine.
    The problem was the new guy I'd hired. He'd used up all the battery
    packs and was to lazy to go back to my filed van to get fresh packs.
    He worked at a local tv station in his home town and hooked up the
    unit to a belt pack he used on on of the stations eng filed units.
    It had both variable volt settings and reversible polarity and this is
    where he screwed up.
    I won't be using him again.
    I'm used to servicing pro gear but that said consumer equipment can
    oft' times be harder to service than a good 3chip broadcast
    camera.(I've had a Sony DXC 3000 that I've been using since 88 and
    have only had to replace the chips once.)
    Just thought I'd ask here and see if there was someone who could help
    me out. I know how difficult oem's can be about service info.
    Thanks again
