Canon inkjet repair??
Discussion in 'Electronic Repair' started by gothika, Feb 9, 2004.
  1. gothika
    gothika Guest
    If ther is a more appropriate NG for this question please give me the
    directions.
    I have a Canon BJC 6000 inkjet printer and I need to know if there's
    any way to test the printhead assembly to see if it's still
    functional?
    It uses the BC-31e cartridge with integrated printheads and the
    separate ink tanks that click into the printhead assembly.
    TIA
  2. Jim Yanik
    Jim Yanik Guest
    Integrated print heads means that the printheads are PART of the ink
    tanks,I thought.
    So that when you change ink tanks,you essentially get a new printhead.
    Perhaps the black ink tank is the one with the integrated printhead,and the
    color tanks insert into that?
    I'd be very leery of refilled ink tanks too,I believe that's what destroyed
    my BJC-620 printhead.
  3. Si Ballenger
    Si Ballenger Guest
    Check comp.periphs.printers
  4. gothika
    gothika Guest
    On the BJC 6000 the printhead is a removable shell that has slots for
    the tanks. The printhead assembly is a click in unit that has the
    printheads and the electrical contact strips. Tanks are separate and
    There is one unit for the yellow, magenta and cyan and a separate one
    for the black.
    It gives the user the most economical solution for inkjet use.
    When a particular color runs out just replace that color tank.
    When the printhead wears out just transfer your tanks over to the new
    printhead cartridge.
    The head units are pricey though and the diagnostic software doesn't
    tell you id the head is dead, just to replace them when you run out of
    ink. I'd hate to buy a new black printhead if the old one is still
    good.(It's about 20 buck over the cost of the tank.)
    I'd just had good luck refilling the black cartridge on my old BJ1000.
    (Had heard that the Canons were the easiest to refill.)
    and thought I'd have a go at the 6000.(It's been in the closet waiting
    for the cost of the ink to come down.)
    I'd heard that there were fixes for burnt out HP cartridges with
    internal heaters/electronics etc.. and was hoping to find out if I
    could do likewise with the canon.
    Thanks again for the reply.
