Michael said:
So, the amount of capacitance also depends on the amplitude of the signal?
Actually, very slightly for an electrolytic, but its an indirect relationship.
UF value is more than just the reactance/frequency relationship?
Biggest uF is best for electrolytics.
Simply doesn't matter for film caps. Film caps simply suffer from big cost/uF.
I've always just used a high value electrolytic (100UF or more) to get as
much audio through as I can and (it always sounded better...more low end).
It's *not just about low-end*. Bigger electrlytics mean smaller signal volts
across the cap. This means less distortion as a result of non-linearity.
Film caps don't have the non-linearity issue but aren't available in practical
sizes for good low-impedance coupling.
I was about to ask why I see values like 3.3uf or 4.7uf on the output of
audio opamps (especially these MKT caps).
I've never seen that but I'm an audio pro and don't bother with audiophool
nonsense.
If you like to use $5 caps suit yourself !
I simply avoid using caps where they aren't needed. Often they aren't
essential. DC coupling is often preferable.
How does the level of signal influence the value of capacitance? (not the
working voltage but the value)
If the signal across an electrolytic exceeds ~ 100 mV they start to distort.
Obviously film caps don't distort ( no relevant mechanism ) but they aren't
available easily in large uF values.
I saw the back to back thing in Walter Jung's "How to pick a
capacitor"....hence my using it. (Not a series back to back....I'm putting
them in parallel to create a non-polarized combination).
Tha sounds intruiging.
I've never tested them 'back-to-back' !
BTW - the THD introduced by electrolytics is small typically and only at low
frequencies ( maybe 0.01% ) but still worth avoiding.
Graham
