Can you really HEAR mkt caps?
Discussion in 'Electronic Design' started by Michael, Feb 3, 2006.
  1. Michael
    Michael Guest
    I know they look good on test equipment but can you really hear the
    difference in an audio circuit with these MKT capacitors?
    I have an analog devices op amp and I've put a couple of 10UF electrolytics
    back to back in a non polarized arrangement on the output and it sounds
    awful good to my ears.
    I ordered some to compare but I'm a cynic by nature.
  2. Pooh Bear
    Pooh Bear Guest
    The idea that different types of film caps have 'a sound' is as plain berserk
    as the audiophool notion that some copper ( the type blessed by companies
    charging a lot of money for theirs ) sounds better too.
    Electrolytics aren't beyond blame though. I could discuss this at length and
    have actually made some measurements of same.
    Unless you actually need to block a DC voltage > ~ 100 mV you should use only
    *one* electrolytic. They don't care about polarisation ( reverse or otherwise )
    this low. Using 2 back to back without the mid-point being biased actually
    makes their influence ( distortion - albeit tiny ) worse.
    Also I would recommend a larger cap for coupling an output. I use 100uF.
    Nothing to do with low frequency cut-off but everything to do with ensuring the
    ac signal across the cap is as tiny as possible.
    Graham
  3. a bit OT but in
    http://tangentsoft.net/audio/opamps.html
    A little quote about OPA132
    "This is a nice family of op-amps. The sound has the typical
    Burr-Brown laid-back nature. It's a bit tubby on the bottom end. This
    is not an exciting sounding chip......"
    Precision stuf, eh?
    martin
  4. Only if you're a true audiophool IMO. ;-)
    I hear that on the cynic stuff. I am interested in seeing your report
    later.
  5. Tim Williams
    Tim Williams Guest
    My MKP's sound pretty good. Idunno about MKT.
    What? I should hope your capacitors make a sound when you run a few hundred
    amperes of LF through them.
    Tim
  6. Rich Grise
    Rich Grise Guest
    LOL!
    Thanks!
    Rich
  7. Rich Grise
    Rich Grise Guest
    I just discovered a couple of LM386s and a .25W, 8ohm speaker in my
    junque box - I wonder if I could make a good audiophool amp? ;-)
    Cheers!
    Rich
  8. Pooh Bear
    Pooh Bear Guest
    How anyone can classify an op-amp as having a 'tubby bottom end' begs belief. I
    guess they don't know much about how negative feedback works.
    Graham
  9. Sjouke Burry
    Sjouke Burry Guest
    An audiophile can hear anything,even .0001 percent
    distorsion,up to 400 KHZ etc, so... ??????
  10. Robert Baer
    Robert Baer Guest
    There are some electrolytics that perform very well with reverse
    voltages up to 40% of forward rating, and are superb up to 10% of rating.
  11. Robert Baer
    Robert Baer Guest
    Low and medium voltage ceramics make a big bang at 500KV....
  12. budgie
    budgie Guest
    Sounds like their wine appreciation writer had to turn in the review.
  13. ehsjr
    ehsjr Guest
    Announcing the new TIP (Trazepoidal Inline Package) family
    of audio op amps, specifically designed to reverse the
    tubby bottom end effects associated with older packages.
    \o /\ Top /
    \ || Bottom /
    Features:
    o Distinctive Pin one marking
    o Directional arrow identifies wider top end for brilliant highs
    o Labeling of *both* top and bottom end
    o Narrowed 6 pin bottom end response eliminates tubbyness
    o Increased top end 10 pin range
    Available in:
    - PbSO4 washed version for acid rock
    - Au plated for golden oldies
    - Platinum finish - recommended for top sellers only
    Prices available on request.
  14. Jim Thompson
    Jim Thompson Guest
    [snip]
    Better copyright that... it'd probably sell ;-)
    ...Jim Thompson
  15. It will only sell if he asks at least $500.00 each.
  16. I almost forgot, it will have to be pumpkin orange in color.
  17. Jim Thompson
    Jim Thompson Guest
    With gold trim ;-)
    ...Jim Thompson
  18. Chris Jones
    Chris Jones Guest
    The distortion produced by an electrolytic capacitor will be smaller than
    the signal across the electrolytic capacitor. In fact, second-order
    distortion will probably decrease with the square of the signal across the
    capacitor and third order distortion will probably decrease with the cube
    of the amplitude of the signal across the capacitor. Therefore in order to
    achieve very low values of distortion, it would suffice to use a large
    value electrolytic capacitor, so that the amplitude of the signal across it
    is small.
    Chris
