Can You Identify This?
Discussion in 'Datasheets, Manuals and Component Identification' started by H2814D, Mar 19, 2022.
  1. H2814D
    H2814D
    107
    12
    Nov 4, 2017
    Hi all, can anyone tell me what this is? I've looked for something similar, and plugged the numbers in a search, without luck. There are two of them right next to a multi voltage output voltage regulating component on an auto radio PCB. The numbering and markings you can see are the only markings on the component. When tested with a multi-meter in the circuit, they seem to test somewhat similar to a diode, but I understand that that is not the best way to test them. Anyone have an idea as to what they are anyway? Thanks in advance for your reply.
  2. Martaine2005
    Martaine2005
    4,203
    1,146
    May 12, 2015
    They look like tantalum capacitors.
    Normally the markings are readable as top number is capacitance in micro farads and lower number is the maximum voltage.
    I don’t know what the circled number is, somebody will inform us both.
    Martin
    gafthehorse likes this.
  3. kellys_eye
    kellys_eye
    4,770
    1,320
    Jun 25, 2010
    Yup, 10uF 15V 'time bomb'.
    Tantalums are notorious for problem causing.........
  4. Martaine2005
    Martaine2005
    4,203
    1,146
    May 12, 2015
    There’s an electronic rock group called The Prodigy. One of their best songs is called “Fire starter”.
    Martin
  5. Bluejets
    Bluejets
    5,688
    1,205
    Oct 5, 2014
    As Martin says, if they were dodgy you wouldn't be able to read anything on the casing.
  6. H2814D
    H2814D
    107
    12
    Nov 4, 2017
    Time Bombs? What sort of "problems" would they cause?
  7. H2814D
    H2814D
    107
    12
    Nov 4, 2017
    Dodgy? Does that mean I would be able to tell if they were bad because I WOULDN'T be able to read the numbers on the casing?
  8. H2814D
    H2814D
    107
    12
    Nov 4, 2017
    Thanks, Martin. Now that you have identified them, I am finding them very easily now.
  9. bertus
    bertus Moderator
    2,568
    1,007
    Nov 8, 2019
    Hello,
    I have several times seen that those tantalium capacitors where burnt and created a short on the board.
    Bertus
  10. Martaine2005
    Martaine2005
    4,203
    1,146
    May 12, 2015
    They have been known to burst into flames.
    Martin
  11. H2814D
    H2814D
    107
    12
    Nov 4, 2017
    Oh. Got it. I removed both of them and they both tested out good as caps, so I can keep looking.
  12. kellys_eye
    kellys_eye
    4,770
    1,320
    Jun 25, 2010
    Randomly removing and testing parts is a long-winded way to a fault. What symptoms do you see and do you have any technical (schematics) information on the device?
  13. H2814D
    H2814D
    107
    12
    Nov 4, 2017
    :) Yep. It sure is. But when that is the only way you have to do things, because I DON'T have a schematic, that is what I have to do. I am limited to the test equipment I have available to me, which is the stuff I would need to test most components at the component level only. Multi-meter, transistor tester, ESR Meter, etc. I have a basic oscilloscope, but am not versed in its use.
    This is part of the Delco CDM I posted about a week ago. The symptoms are in that thread. You replied to it as well. I am still troubleshooting it without a schematic. I have a long wind. :D
