| On Tue, 4 May 2004 14:51:46 -0700, "Terry Given"
[email protected]> posted
| this:
| >| >> Posted to abse. I bought 500 of these last summer. They're unmarked
| >> and appear to be open circuit to a DVM. Could they be some sort of
| >> flash arrestor? Can't honestly say I've seen this component before.
| >> Size is about one inch across.
| >clearly its a MOV with integral fuse (see earlier thread on MOV as
snubber).
| >If it tests as open-circuit the fuse might be blown. measure its
| >capacitance - very little = blown fuse. If you have 500 of them,
dismantle
| >one, the fuse will be obvious. test it with a variac + 25W lamp +
step-up
| >xfmr + rectifier & ammeter, ie wind up the volts slowly and watch it
clamp.
| >cheers
| >Terry
| Clearly, the lump on top of the disk is in *parallel* with the disk.
| Not very likely to be a fuse. Fuses usually go in series with things.
| Paul, carefully crush the coating on the device with a pair of pliers
to
| remove it. Then give us another picture.
| Jim
Excellent diagnosis, in parallel ay........ my sentiments exactly. Nuff
said, ho ho ho.
RC contact snubber???
