Can you identify this electrical piece of circuitry?, Needle in a haystack scenario.
Discussion in 'Power Electronics' started by TheRedAnarchist, Jan 8, 2020.
  1. TheRedAnarchist
    TheRedAnarchist
    4
    Jan 8, 2020
    Recently acquired this piece of work, no idea the purpose or value of it. It was taken off of an old copier scrapped for parts. Just looking for it to be possibly identified, so I know exactly what I’m in possession of.
    Link to pictures: https://postimg.cc/gallery/23hrvxefk/
  2. Kabelsalat
    Kabelsalat
    117
    22
    Jul 5, 2011
    You should add an image from side view too, and I can only guess this is a rotating part.
    Then I guess this has to do with lamp reflection, but I haven't put my mind into old copiers.
  3. TheRedAnarchist
    TheRedAnarchist
    4
    Jan 8, 2020
  4. hevans1944
    hevans1944 Hop - AC8NS
    4,377
    2,046
    Jun 21, 2012
    It's a driver board that contains hexagonal first-surface mirror facets used either to optically scan documents or to write images on a photosensitive film that carries the image, via electrostatically attracted toner, to the copy paper. The motor is missing, and precision bearings in the motor may be an integral part of the mirror suspension. Nice paper weight and conversation piece if you can remove the mirror thingy from the circuit board.
  5. TheRedAnarchist
    TheRedAnarchist
    4
    Jan 8, 2020
    Thank you your reply is much appreciated!
  6. Hunter64
    Hunter64
    27
    10
    Nov 20, 2018
    The motor isn't missing! Its between the pcb and the mirrors, visible in the side-view.
    The construction is similar to some drum-motors is laser printers.
    Check the datasheet for the driver ic for more information. Probably 24DC and a few control lines to get it spinning.
  7. TheRedAnarchist
    TheRedAnarchist
    4
    Jan 8, 2020
    Oh alright! Much thanks!
