Can we check resistance of mos transsitor directly?
Discussion in 'Electronic Basics' started by boki, May 2, 2004.
  1. boki
    boki Guest
    Dear All,
    Can we check resistance of mos transsitor directly in spice?
    Could you please tell me the command?
    Thanks a lot.
    Boki.
  2. Do you mean calculating V/I?
    Kevin Aylward
    http://www.anasoft.co.uk
  3. Boki
    Boki Guest
    Sorry, no, I mean read mos transistor's resistance value directly, when mos
    is working in linear region, for example: apply mos as a switch.
    We can calculate mos resistance by:
    R=1/[uCox(W/L)(Vgs-Vt)]
    but, the real resistance value will change with other parameter, so, we
    can't calculate it very accuracy,
    if possible, I want to simulate it and get its resistance value directly,
    could I?
    Thank you very much.
    Regards,
    Boki.
