Can this be used?
Discussion in 'Microcontrollers, Programming and IoT' started by bigone5500, Oct 10, 2014.
  1. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
  2. (*steve*)
    25,482
    2,830
    That has on-chi[p ROM. This means that you won't be able to reprogram it.
  3. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    Thanks Steve. It still looks cool sitting on my desk. Makes a great conversation piece too.
  4. ElectTech
    ElectTech
    Oct 21, 2014
    That is true for the P8398 part but the p8798 should have a quartz window that when uncovered allows an EPROM eraser to erase the contents. Then with the proper programmer, it can be re-programmed. The E in EPROM stands for Erasable. True of most, if not all of the Intel processors and memories, as well as those from other manufacturers.
  5. (*steve*)
    25,482
    2,830
    Looking at the datasheet again, it does list the 8798 as both "user programmable" and "OTP" (one time programmable).
    Since it mentions EPROM, if the device has a quartz window you can likely erase it, otherwise not :-(
