L
LPEL98
I have some boards that are used in automotive apps. They are not
meant to get wet, but you know how that goes - sometimes "stuff"
happens. I know I could reduce my failure rate in the field with a
conformal coating that kept the water out.
My concerns is that a coating might restrict heat transfer and cause
my product to run hotter - that would not be desirable. Also, I am
concerend it would be a real bear to rework boards if they have this
coating on them. Is there some kind of coating that is relatively
easy to remove? I'm thinking something that could be relatively
easily peeled off certain components if they need replaced and the
coating could be re-applied. If you guys have ever used that latex
soldermask stuff - something like that would be great - splooge it on,
and it peels off easily after you're done. Some coatings I've seen
are like varnish and would be a bear to remove. Is there easier ones
out there?
Also, how expensive are these coatings? Say for a 3"x2" board. If it
cost me a nickel or dime a board it would probably be worth it, if it
could be removed easily for rework.
out there?
