W
Watson A.Name - \Watt Sun, the Dark Remover\
I went to the veroboard website
http://www.verotl.com/products/index.cfm?content_id=2424A965-4AF2-433B-9
589A039D35545F5
and found a choice of verious sized boards to choos from. I also went
to the BISCO website, which is their U.S. distribs, but that was useless
because they need a part number, like no catalog whatsoever.
So I'm looking at the URL above, and I don't know which to choose from.
First off, the only VB I've seen was phenolic, not epoxy, so I guess I
want to order some of that, since it's easy to work with. And I know I
want single sided with 0.1" hole spacing. But the SRBP has me stumped,
I've never heard of it before - must be a U.K. term? I found this URL
http://www.plasticshimsandgaskets.co.uk/psg_apps/stage1/srbp.htm
which seems to allude to it being phenolic, but I'm not sure.
So I figured out that the VB # 01-0014 looks like it's a convenient
size, and presumably it's phenolic. Is this a commonly used size? What
_is_ the size that one would find in a store?
I went to BISCO website and searched under Vero for that number, but all
I get is a we're sorry.. can't find it message. This website is useless
because it doesn't give any list to choose from. I went to RSWW and
they showed a list, so I'm guesing that the stripboard is the same as
veroboard. It looks like I'm on the right path, but I haven't been
successful in finding any info about it from their U.S. distrib. Likely
as not, I could probably order from a distrib in the U.K. and get it
with less problems. Thanks for any help.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
589A039D35545F5
