Can somebody take a look at this circuit for me?
M
Michael Noone
Hi - can anybody here tell me if this circuit will work? The idea is for it
to take an input of 0-10V DC at point VIN and output 100 times that at
VOUT. This is the circuit, drawn up with Cadsoft Eagle:
https://netfiles.uiuc.edu/mnoone/www/Electronics/LinearAmplifier.jpg.
Op-Amp is a TI TLC2274: http://www-s.ti.com/sc/ds/tlc2274a.pdf (beware -
fairly large datasheet)
Mosfets are both Internation Recifier IRFBG20: http://www.irf.com/product-
info/datasheets/data/irfbg20.pdf
Before I go any further - I should say that this is pretty much 100% John
Field's design (with some minor modifications by me in the choice of a
higher voltage FET and a higher input voltage) - but I figure I've pestered
him enough so I should post it here instead.
I tried building this circuit today and I ended up frying the op-amp, and
possibly one of the FETs. I'm not exactly sure how that happened, possibly
a short, though my wiring looks fine to me. I'm not worried about it as I
ordered up plenty of both the fets and the op-amps though.
Anyways - what do you all think?
-Michael J. Noone
PS I tried to test this circuit out with LTSpice - but I was unsuccessful.
Can somebody tell me what I'm doing wrong? This is my LTSpice file:
https://netfiles.uiuc.edu/mnoone/www/Electronics/linear amplifier.asc and
this file needs to be in the same directory:
https://netfiles.uiuc.edu/mnoone/www/Electronics/irfbg20.spi
John Larkin
I'd add a zener s-g on the upper fet to keep from blowing out the gate
under various weird conditions.
The loop may be unstable, and needs analysis. A resistor in series
with C1 might wind up being needed.
Otherwise, should work.
John
P
Pooh Bear
Are you really sure that your active load ( U$2 ) is meant to be configured
like that ?
Oh - it's just the way you drew it that's confusing. How *do* you generate such
odd component references btw ?
It's quite likely unstable. Try using sensible feedback Rs for starters like 1M
( watch the wattage ) and 1k
You can protect the op-amp by adding clamp diodes to its supply rails btw.
Graham
One problem with power MOSFETs is that they have a nasty tendency to
self-oscillation at a few hundred MHz, which can often be tamed by a
low value resistor (10R to 100R) in series with the gate - R2 probably
does this job for U1, but you might want to try adding such a resistor
at U2.
As John Larkin has pointed out, the delays around the feedback loop are
fairly high, and the stability could be a worry.
The 8pF input capacitance of the op amp with 100M at R3 gives an
800usec RC delay around the outer feedback loop, which R5/C1 seems to
be intended to take care of, but I too have found myself putting a
resistor in series with C1 in similar situations.
Bill Sloman, Nijmegen
C
colin
I would say this would be essential, without it the top mosfet would
undoubdetly blow as soon as the botom mosfet turns on hard as the top gate
will be pulled down to 0v but there is nothing to pul the output down so the
full output voltage wil apear acros the gate, also any leakage on the top
mosfet wil have no where to go and try to go through the gate.
This looks like quite a comon output configuration but it is mising that
diode, wich provides a path for the botom mosfet to pull the putput low.
yeah, wil be needed if the op amp isnt unity gain stable.
id add a zener on the gate of the botom mosfet too to be safe, if the output
falls instantaneously the gate may well be puled negative by more than 20v
by the gate drain capacitance, as the 1k gate resistor probably wont stop
this but a zener will.
Colin.
M
Michael Noone
configured like that ?
generate such odd component references btw ?
What do you mean odd component references? The names are all auto generated
by Eagle.
starters like 1M ( watch the wattage ) and 1k
The size of the resistors used in the voltage divider circuit will affect
the performance of the circuit? I chose those high values as I figured
they'd be fairly easy to obtain and not consume much power - but I
definitely can change to a smaller set of resistors if needed.
btw.
Graham
Can you elaborate on this? I'm afraid I'm not familiar with the term "clamp
diode" - and googling it turned up many results relating to things like
relays, (where I am familiar with the use of diodes to dissipate the
inductive energy stored in the coil).
Thanks!
-Michael
M
Michael Noone
[email protected] wrote in
at U2.
I forgot to mention this in my first post - but this circuit will not be
run at a very high speed. It will be switched to a voltage, and then
held there for a second or so. In testing a similar circuit I found it
took about 30ms to stabilize, which is ok, but if I could get it to
stabilize faster than that that would be ideal. Also, I'm not sure how
this circuit will handle varying loads. If it matters - current through
the output will be very low, probabaly in the micro amp range. So with
that said - do you think I still need a resistor for U2?
are fairly high, and the stability could be a worry.
Right - is there any way to improve upon this? I'm afraid I'm not
particuarly experienced when it comes to FET amplifier design.
Would a different op-amp with a lower input capacitance improve upon
this? I am not stuck to the TLC2274 in any way.
Thanks!
Michael Noone
M
Michael Noone
Hi John - what exactly is a Zener s-g? I've never seen the term s-g before,
and I was unable to find anything on google.
John
-Michael
B
Bill Sloman
How you use the circuit doesn't affect U2's tendency to self-oscillation. If
the gain around the relevant loop is high enough, Johnson noise will be
enough to start the oscillation. We had enough trouble with power FETs going
into self-oscillation at Cambridge Instruments that a 10R resistor in series
with the gate was always designed in - if we had the pads on the printed
circuit it was easy to swap in a higher value resistpr if necessary.
The nasty part of the problem was that self-oscillation at over 100MHz
wasn't always visible on cheap portable oscilliscopes, so the service
engineers could get thoroughly puzzled.
It isn't a problem that is specific to FET amplifiers - all negative
feedback amplifiers can oscillate if there is too much delay around the
feedback loop. The trick is to make sure that the loop gain (plotted against
frequency) falls to less than one before the phase shift has reached 180
degrees.
The Texas Instrument MOSFET input op amps do have a relatively high input
capacitance, and I got caught years ago by the TLC2201, back when TI didn't
include that bit of information in the data sheet, but 8pF isn't much higher
than the 2-3pF you see with most op amps.
Lowering R3 and R4 would be easier than finding a new op amp, but all you
really need to do is make sure that the negative feedback around the op amp
isn't greater than one at frequencies where the phase shift through the
feedback paths exceeds 180 degrees.
Any decent electronics text covers this subject - Horowitz and (Win) Hill's
"The Art of Electronics" has a couple of pages on the subject (chapter 4 -
sections 4.33. 4.34 and 4.35 are well worth reading).
John Larkin
Sorry, I meant connect a zener from the source to the gate of the top
fet. Allow the gate to go, say, a maximum of +10 volts above the
source. The zener will also keep the gate from going more than about
0.6 negative relative to the source.
John
H
Homer.Simpson
is for it to take an input of 0-10V DC at point VIN and output
100 times that at VOUT. This is the circuit, drawn up with
Cadsoft Eagle:
pg.
Maybe I'm missing something here?
Shouldn't the upper FET be a PFET with the 1Meg from Gate to Source?
Additionally, I'd think you'd want to provide the 1/1000 feedback to
the negative input of the OPAMP.... with the positive input getting
the command voltage.
Otherwise, can someone give me quick verbal circuit description?
H
Homer.Simpson
Source?
to the negative input of the OPAMP.... with the positive input
getting the command voltage.
Here's a scaled down version:
http://www.cotse.net/users/reverend/amp_homer.png
http://www.cotse.net/users/reverend/linear_amplifier_homer.asc
John Larkin
My guess.
U2 Gate and Source should have a TVS (transient Voltage Suppresser)
diode rated for just at or below the max gate voltage be gate voltage.
also the resistor values on the + input seem kind of high, i would
think that internal capacitance of the Op-amp + input may cause some
time delay related problems in biasing! in that case, i would use
a lower divider network values. 10k , 100K looks good.
P.S.
zener diodes can also be used for the gate suppression idea how ever,
they do not offer the speed of response like a TVS does.
A TVS *is* a zener, usually a big, slow (as in high capacitance) one.
John
H
Homer.Simpson
Jamie
-Michael J. Noone
My guess.
P.S.
M
Mac
by Eagle.
You would put the diode between the pin you want to protect, and the
positive supply rail in such a way that it is normally reverse biased.
Only if the voltage at the protected pin goes above the supply Voltage
does the diode experience forward bias. Is that clear enough?
Something like this: (Use courier or other fixed-width font for ASCII art
schematic)
VCC
| --- clamp
| / \ diode
| \----+------> To dangerous load
| / --- clamp
| /| / \ diode
GND
Thanks!
-Michael
In your circuit, you might want to protect the non-inverting input pin and
or the output pin.
I agree with the others who say that the upper FET definitely needs Zener
protection. Might as well add it for the lower one, too. You would use
maybe a 10 V Zener in such a way that it Zeners when Vgs is > 10 V.
Like this: (Use courier or other fixed-width font)
1kV
---+ Drain
gate ---+---|| N-channel MOSFET
~ ----+ Source
Zener / \ |
diode ----- |
+--------+------- Vout
I also have to point out that you are operating a 1000 Volt transistor
with, potentially, 1000 Volts across it. Normally, I would not
recommend designing with zero margin.
--Mac
C
colin
Homer.Simpson said:
Homer.Simpson said
This one's passed validation and is ready for mass production:
http://www.cotse.net/users/reverend/amp_homer_2.png
http://www.cotse.net/users/reverend/linear_amplifier_homer_2.asc
Just don't ship it anywhere near me. Are you really messing with 1KV?
well the upper fet is a source folower (non inverting),
the botom fet is a comon source amplifier with negative gain,
therefor overall negative feedback needs to go to the + of the op amp
your circuit has 2 subsequent inverting gain stages, wich is more of a
problem for stability,
and draws a fair bit more power from the 1kv
Colin =^.^=
C
colin
the 8pf input capacitance sees the 100m in parallel with 1m so this isnt
realy that bad, the 10k/100nf will determine the response mostly (1ms). you
could decrease the 100nf untill you get the required response, you may need
to put a resistor in series with it for stability/setling time.
if you still realy have problems geting it stable, reducing the gain of the
output amplifier with its own feedback loop might help with stability, such
as a resistor in series with a capacitor from the output to the botom fet
gate.
I did a HV amp once before but had to use several mosfets in series to get
the voltage, it was a nightmare, i never did fully work out all the diferent
modes of oscilations that seemd to be present.
Colin =^.^=
H
Homer.Simpson
amp
of a problem for stability,
Thanks. My limited experimentation with this circuit in LTSPICE
confirmed it was very jumpy. I'd hate to run it a 1KV. ;-)
W
Winfield Hill
Homer.Simpson wrote...
Not to mention your FET model was no doubt useless below 10mA.
An problem I've discussed at length on these pages. Remember,
always test your spice models with bench measurements.
