Can you plug in a 10amp, 12volt manual car battery charger into an outlet controlled by a 600watt light dimmer to control the output down from 10amps to a lesser amp rating? I Want to use the charger as an adjustable power supply for a hot wire foam cutter. Thanks, I'm a beginner in electronics.
Categories
Platforms
Content
