M
Martin Lynch
Can I use a multimeter to test your standard AA or AAA
batteries?
Not sure if I should be checking for voltage or current.
Seems like checking voltage doesnt give me accurate
results, as a "dead" battery will often still read
1.2 volts or so.
And problem with current is my 1600 mAh batteries seem
to be rated to high for the multimeter.
What does a "battery tester" that is designed specifically
for this actually measure?
batteries?
1.2 volts or so.
