D
DaveC
This question has evolved out of a related question posted elsewhere in this
NG, but I consider that it is now "buried" in the many excellent responses to
that question. So...
Can I use a crystal in place of a ceramic resonator? This circuit is the
clock for a National Semi proprietary (and hence, no pin data available)
microcontroller in a car alarm. Two 33uF caps tie the 3.58 MHz res. to gnd in
a "PI" config. One end of the res. is tied directly to the Clock + (I
presume) pin of the uP, and a 1M-ohm resistor ties the other end to the Clock
- pin.
I can get a resonator mail-order, but I can find only crystals locally. I
will order the resonator if that is what is called for, but if I can
substitute, I can buy that today.
- pin.
