Can I replace NiCad with NiMH?
Discussion in 'Electronic Basics' started by Mitch, Mar 28, 2007.
  1. Mitch
    Mitch Guest
    I have some rechargable wireless headphones that I use on the
    treadmill. The NiCads have developed so much memory that they only
    last about 1/2 hour.
    Can I replace them with NiMH? Will the charging dock handle them the
    same?
  2. redbelly
    redbelly Guest
    Your headphones will probably work fine with NiMH, BUT YOU MUST USE A
    DIFFERENT CHARGER, ONE MEANT FOR NIMH.
    I repeat, do not charge NiMH batteries in a NiCad charger.
    Mark
  3. Lionel
    Lionel Guest
    Yes, it should work fine. I use NiMH cells on everything I have that
    takes NiCads, including my expensive Canon 550-EX flashgun.
    That's a different story. If it trickle charges (eg; 12+ hours on
    NiCad cells), it should be fine. If it uses a fast-charge system, it
    might be okay, but you're tempting fate. Just go & spend $20 on a
    generic NiMH fast charger.
  4. Mitch
    Mitch Guest
    Glad I asked...thanks!
  5. Eeyore
    Eeyore Guest
    Almost invariably they're fine.
    Graham
  6. Eeyore
    Eeyore Guest
    Why ?
    Graham
  7. Rich Grise
    Rich Grise Guest
    It lets the magic smoke out.
    Good Luck!
    Rich
  8. Old Mac User
    Old Mac User Guest
    Because that will ruin the NiMH battery and may smoke up your
    workshop. OMU
  9. Puckdropper
    Puckdropper Guest
    *snip: Why not to charge NiMH with NiCd chargers*
    I've had NiMH on a NiCd charger (NiMH/NiCD switchable) for somewhere
    around 15 minutes once. While the batteries appear to have survied
    without incident, they did get really hot. It makes me wonder if they
    could explode. (Heat --> pressure --> POW!)
    Puckdropper
