Hi, I'm new to hobby electronics, and I'm replacing a popped fuse on my soldering station. I have included a picture of the bottom of the station (which says that it needs a T630mA 250V fuse), as well as the fuse itself (which is a glass fuse). I want to check my understanding of fuses with you guys.
This particular fuse is a "slow-blow" (T) fuse, and will blow after a small amount of time suffering under a current of greater than .63 amps, correct? It will tolerate up to 250 volts, correct?
Also, I'm looking up replacement fuses, and I see there are glass and ceramic fuses available. Considering this is for a soldering iron, should I get a ceramic fuse instead? Are they interchangeable? Would the ceramic fuse be safer?
Thanks.
Thanks.
