can I plug 'host-powered' pc speakers into the mains?
Discussion in 'Electronic Basics' started by _, Apr 17, 2004.
  1. _
    _ Guest
    Hi
    I've had to replace an old computer psu, unfortunately the replacement did
    not come with the pass-through power connector that I plugged the speakers
    into. It's an IEC type (I think...!)
    Can I simply cut off the connector and add a standard mains plug instead or
    is that a huge no-no?
    I'm UK based, electrical supply 230-240 volts. The speakers specs are
    230v - 50hz.
    thanks
  2. soundman
    soundman Guest
    Yes, you can. Make sure you use the right fuse (almost certainly a 5A).
    Colour: Brown - live, Blue - neutral, yellow/green - Earth. If the wire
    colours are different, come back and ask for information if you need to.
  3. David Harmon
    David Harmon Guest
    On Sat, 17 Apr 2004 15:58:39 +0000 (UTC) in sci.electronics.basics, "_"
    You can do that. It would be easier to plug it to one of the many loose
    IEC to mains cords that are usually lying around spare.
  4. _
    _ Guest
    I've plugged the speaker connector into an IEC to mains cord (5A) and it
    works fine! I'll run with that for a while and if I need the cable I'll
    wire a plug on.
    Soundman and David - thanks for your help!
  5. soundman
    soundman Guest
    You are very welcome. It's nice to have an acknowledgement.
