Can I mix 3 different brands of electrolytic capacitors?
Discussion in 'General Electronics Discussion' started by aventy28, Jun 18, 2020.
  1. aventy28
    aventy28
    11
    Jan 30, 2020
    I have this power circuit board for a mini HiFi system, that has leaky caps, I bought the capacitors needed for the replacement...however there are of three different brands: Jamicon, Capxon and
    Rubycon.
    Replacement of leaky caps are
    - 6 Jamicon 1000uf 50v
    - 2 Jamicon 470uf 35v
    - 2 Nichicon 10uf 35v
    The ones I bought for this replacement (and the only ones available due to this COVID19 situation) are
    - for the 1000uf 50v: 4 are Capxon brands & 2 are Jamicon brands but 63v were available and 50v were out of stock, so I bought them.
    - for 470uf 35v: 2 Jamicons were bought
    - for 10uf 35v: 2 Rubycons were bought
    My question is: is it ok to replace the leaky caps with the mentioned different brands of new ones above?
    Or should I just wait for this COVID19 situation to be over, and just get the same brands of those leaky caps when it restock?
  2. Externet
    Externet
    736
    158
    Aug 24, 2009
    Using different brands of capacitors should not be detrimental. Try not to use the brands recognized as trouble-prone.
    hevans1944, aventy28 and davenn like this.
  3. bertus
    bertus Moderator
    683
    237
    Nov 8, 2019
    Hello,
    There is no problem using an 63 V capacitor in stead of an 50 V type.
    The 63 V type will likely last longer as it has more headroom and is less stressed.
    Bertus
    hevans1944, davenn and aventy28 like this.
  4. shrtrnd
    shrtrnd
    3,734
    478
    Jan 15, 2010
    Above responses all true.
    Hopefully, you won't have a problem, but as Externet alluded to, there are a lot of counterfeit Chinese components loose
    out there that don't hold-up. It pays to try to buy brand-names from reputable suppliers. (even though the brand-name can also be counterfeited by the Chinese).
    I'm mentioning this in case you experience a problem shortly after your repair. Don't assume that just because you replaced
    those caps recently, that they don't need to be retested if a problem reoccurs.
    Good luck with the repair.
    hevans1944 and bertus like this.
  5. hevans1944
    hevans1944 Hop - AC8NS
    4,473
    2,084
    Jun 21, 2012
    If it is possible to do so, it is a good idea to check the electrolytic capacitors for leakage current at their operating voltage and to test them for their Effective Series Resistance (ESR) over the range of frequencies each is expected to "filter" or otherwise pass through a signal.
    ESR testers seem to be more common than leakage testers, but you can cobble up your own leakage test with a variable-voltage DC power supply and a sensitive microammeter, all connected in series across the capacitor under test. Pay attention to getting the power supply polarity correct because electrolytic capacitors are (usually) polarized. Also include in this test circuit a normally-closed momentary switch (toggle or push-button) in parallel with the microammeter or a sensitive milliammeter. This is to allow the capacitor to charge to its working voltage without passing the charging current through the current-measuring device.
    After adjusting the power supply to the working voltage, wait a few seconds before actuating and quickly de-actuating the switch to temporarily remove the short across the current meter. If there was any indication of current, wait a few more seconds and repeat the actuation and de-actuation of the normally-closed switch. The goal is to measure zero leakage current, sourced by the variable-voltage DC power supply to the capacitor, after the capacitor is charged to its normal operating voltage.
    Of course nothing is perfect, so you might see a microampere or so of leakage through a perfectly good electrolytic capacitor, but certainly nothing in the milliampere range or higher.
    bushtech likes this.
  6. caps
    caps
    168
    8
    Jul 29, 2018
    To check the electrolytic capacitors, you can use a Chinese transistor tester.
    He has a Vloss function (leakage).
