P
Peabody
I have 5VDC wall wort power supply, which is a switching supply, and
it has a typical barrel connector. But I rigged up a small one-inch
square pc board with a USB socket and a barrel socket mounted on it.
So, I can use the power supply as a USB power source for charging my
MP3 player and other things.
But, when I used this power supply to play music, rather than just
charge the player, it was clear there's a good bit of noise in the
supply which doesn't show up when batteries are used.
I can't regulate the supply because I need the full 5V, but I
wondered if I can add things to the little circuit board that would
reduce the noise - such as a series inductor, or a large capacitor
to ground, or both. Will those things work, or do they screw things
up?
Pics of this setup are here:
http://drop.io/owhsijhen
By the way, for future reference, a dumb USB power supply should
have its data pins shorted together.
up?
