I "somewhat" followed an Instructable and ordered a bunch of P channel MOSFETS http://www.irf.com/product-info/datasheets/data/irf9z34npbf.pdf but they haven't arrive yet so haven't tested my cunning plan which I'll detail below...
The original schematics were driving them like in this picture http://www.bristolwatch.com/ele/img/tr9a.gif i.e. a "switched on" transistor makes voltage low from VCC to Collector and turns on MOSFET, and switched off transistor makes voltage high from VCC to Collector and turns off MOSFET... that's all good I understand how that works.
But in that original design, they were driving 8 transistor/MOSFET pairs from 8 microcontroller pins... I figure I would rather just use a 74HC138 because I only need the 8 mutually exclusive.
Having inverted outputs i.e. active low, can I just connect the output pins from the 138 directly to the MOSFET gate?? "low" = MOSFET on, "high" = MOSFET off, no?
