E
Eeyore
krw said:I read it as a -20dB signal is inaudible buried in the 0dB signal
(I.e. "noise *ratio*").
He may have meant ~ 20 dB SPL i.e. his hearing is impaired by ~ 20dB.
Graham
Rich, "-20 dB" with no units indicator is a ratio between two signals, not
an absolute value. -20 dB referred to a shuttle takeoff at 1000 meters is
still very, very loud. -20 dBm is still a solid signal, about what you get
from a telephone with a soft voiced person. What scale did you really
mean?
Have you seen that price for one of these lately ???
I still have a few around, but the wire stripper broke off.
I thought I would be a new one, but $25+ was just too much.
Rich said:No, krw is exactly right - see my response to joseph2k.
The point is, -20 dB relative to a comfortable listening level is not
noticeable to normal people.
I meant "20 dB down relative to a comfortable listening level." At least,
that's what they told me when I was investigating "subliminal tapes",
which were big with "new age" people who believe in psychic healing
I had to take my Malibu back to Piper in Boca Raton several times for
maintenance. The thunderstorms and humidity were quite impressive!
I used to smoke then. I would go out on a back balcony to enjoy the view of
a small pond lined with trees.
One night I noticed a pair of eyes staring back at me. They belonged to the
biggest alligator I have ever seen. I know how fast they can run, and I
don't mind saying that frightened the daylights out of me.
Then I discovered the door had closed and locked, and there was no way to
get back in.
Fortunately, a waitress decided at that moment to take a smoke break, and
came out on the balcony. I showed her the alligator, but she didn't mind.
She knew all about him. But that was the end of smoke breaks for me
Is that what you were referring to?
I'm not familiar with this. What do you mean by scan them at 500Hz?
I thought "subliminal" was 6.66dB down.
nevermind.
Whether or not tempis fugit "scans" in matrix fashion or just checks stateEeyore said:Look, he's new to this and frankly his first MCU project doesn't need
keyscanning to save I/O lines and it would likely degrade his background
noise with a nasty buzz.
Graham
Google wants way too damn many long lived cookies for this one. Even when iSpehro said:The thunderstorms (and resulting electrical disturbances), yes. Never
had a circuit affected by a 'gator, AFAIK.
A story you might enjoy:-
http://tinyurl.com/288q4z
Best regards,
Spehro Pefhany
joseph2k said:Whether or not tempis fugit "scans" in matrix fashion or just checks state
one by one fast enough to be interactive, say "on the measure", all the
switches must be sampled at least 100 times a second.
Thus some "digital noise" is generated.
switches must be sampled at least 100 times a second. Thus some "digital
MooseFET said:Constant frequencies are much easier to hear than single clicks.
MooseFET said:You don't need to scan unless a key is actually pressed:
Drive the entire RowPort low.
Drive the entire ColPort High.
Watch the ColPort for != 0FFH
Once you know the key is pressed, you can use log2(Rows) steps to
figure out which key.
The human ear routinely picks out such signals with surprizing ease andkrw said:I read it as a -20dB signal is inaudible buried in the 0dB signal
Personally i find 30 dB SPL to 60 dB SPL to be my most confortable rangeRich said:No, krw is exactly right - see my response to joseph2k.
I can't speak for those with hypersensitivity disorder, however.
Cheers!
Rich
The penny hadn't dropped earlier but I see what you're doing now.
I'm just wondering if it can be upset by a simultaneous depression of 2 or more
keys.
Then again there's ebay ! The 89C52 should do the job IIRC.
http://cgi.ebay.com/5-x-ATMEL-89C52...2QQihZ013QQcategoryZ50915QQrdZ1QQcmdZViewItem
5 of them for $18 !
But then again there's this !
http://cgi.ebay.com/Burner-Free-805...1QQihZ015QQcategoryZ50915QQrdZ1QQcmdZViewItem
It looks perfect for your needs. I'd ask if they can supply a suitable chip
althoiugh if it'll program the Philips 89C51, I'd expect it to do the above
Atmel 89C52 as well
