Can anyone identify these capacitors?
Discussion in 'General Electronics Discussion' started by deadvirus, Aug 18, 2012.
  1. deadvirus
    deadvirus
    Aug 18, 2012
    These are on a laptop motherboard but I can't get the schematic for it.
    [​IMG]
    [​IMG]
    [​IMG]
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    They are Fujitsu caps, first line is the series... I believe Fuijitsu sold the capacitor lines off to Nichicon now so series might have changed...
    Second line is the value, using normal 3 digit capacitor codes (example 331 = 330pF & 391 = 390pF)
    Third line is the voltage rating
  3. deadvirus
    deadvirus
    Aug 18, 2012
    Thank you so much!!
  4. alfa88
    alfa88
    344
    5
    Dec 1, 2010
    That red mark looks like a polarizing indication. Do you think they might be electrolytics and perhaps a much higher value. Example: 331=330uF.
  5. gorgon
    gorgon
    603
    24
    Jun 6, 2011
    From what I've seen before the value is based on uF, not pF in this case.
    331 is 330uF
    TOK ;)
  6. davenn
    davenn Moderator
    13,901
    1,971
    agreed, you are not likely to see 330pF electrolytic caps ;)
  7. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Good catch...
  8. (*steve*)
    25,500
    2,840
    In addition, these are solid polymer capacitors, similar to a VERY low ESR electrolytic capacitor.
    Check this thread for a recent query about almost exactly the same thing where you'll find some specific information.
  9. sandipgolani
    sandipgolani
    Aug 21, 2012
    These are in modern motherboards are called as solid state capacitors they are solid polymer capacitors. If you see some old motherboards you will find approx 12000uF to 20000 uF capacitance where used but instead today its just total around 1200uF to 1600 uF capacitance is used. So as steve said it has a very low ESR.
