P
Paul Burridge
Hi guys,
May I direct your attention to the following:
http://www.burridge8333.fsbusiness.co.uk/triangle.gif
Where you will find a very simple common-source FET stage that gives
some rather odd results when simulated. It feeds a 0.5mV AC sine
voltage of 10Khz to the gate of the FET. The output is a reasonable
replication of the input signal shape, but upon removing the inductor
(which I had to insert to prevent this problem) the output turns into
a perfect triangle wave. This gross distortion of the input signal
only seems to happen at very small input levels, but nevertheless, I
can think of nothing in the real world that might explain it. Could it
be some sort of peculiarity with the intricacies of spice signal
sources of which I am ignorant? If not, how is this sine-to-triangle
conversion taking place?
THanks,
p.
THanks,
p.
