can a comparator pull down to a negative rail
Discussion in 'Electronic Design' started by panfilero, May 6, 2013.
  1. panfilero
    panfilero Guest
    I would like to use a comparator so that it's output is either open drain (or collector) or it's pulled down to its negative rail (Let's say -5V for my application) I've looked at a couple of comparators, and they have +Vin, -Vin, and GND pins... but from looking at the datasheets it doesn't look like they can output their negative rail... am I right about this? if i am, then what's the point of the -Vin input?
    I was looking at the LT1011
    http://cds.linear.com/docs/en/datasheet/1011afe.pdf
    and the LM319
    http://www.ti.com/lit/ds/snosbj2a/snosbj2a.pdf
    much thanks!
  2. panfilero
    panfilero Guest
    ahh ok, so I could set up my rails at +/-10V and tie my ground to -5V and should be good to go then... great.
    - thanks
  3. Tim Williams
    Tim Williams Guest
    Comparators like the LM319 (LM311, ...) would be better called
    "uncommitted transistor output". Like the TL494 outputs, if you're
    familiar with it. You can use it for pull-up (OUT to +V, output from
    "GND") or pull-down (normal), or whatever your imagination can come up
    with.
    Other ones, made for specific logic levels (LM360, TTL level, comes to
    mind), may be more particular about voltages. In the latter case, for
    example, obviously you need the analog supplies to be more than the analog
    input voltages (so you could do +/-5V for a [-3, 3V] range, say), and the
    output has to be referenced to whatever it connects to (i.e., +5V and GND,
    or insert-logic-level-here). Consider: TTL, CMOS, LVDS, ECL...
    Tim
    Deep Friar: a very philosophical monk.
    Website: http://seventransistorlabs.com
    and the LM319
    much thanks!
