Can a commutator be made to produce dc current turning in both directions?
Discussion in 'General Electronics Discussion' started by James Robieson, Oct 16, 2016.
  1. James Robieson
    James Robieson
    3
    Oct 16, 2016
  2. Minder
    Minder
    3,102
    664
    Apr 24, 2015
    It does, if referring to a DC motor/generator.
    If wishing to maintain a certain polarity regardless of direction, then a simple bridge rectifier on the output will do it.
    M.
    hevans1944 and James Robieson like this.
  3. James Robieson
    James Robieson
    3
    Oct 16, 2016
    OK Minder,Thank you
  4. daberbaber
    daberbaber
    18
    Feb 2, 2012
    Minder's comment answers your question and gives a great tip for maintaining polarity of the voltage coming from the commutator. And the field is supplied by a PM permanent magnet. In a car system however and in many other motors, the field is supplied by an outside source and this will complicate any attempts to use a motor for a generator/alternator.
  5. James Robieson
    James Robieson
    3
    Oct 16, 2016
    Ok daberbaber
    Thank you, that clears up a lot things.
