Camera on RS232 =? Micro-USB module + WebCam
Discussion in 'Hobby Electronics' started by Kouso Wieaka, Aug 25, 2005.
  1. Kouso Wieaka
    Kouso Wieaka Guest
    I recently saw a Micro-USB module on Dontronics's web site
    (http://www.dontronics.com/micro-usb.html). Appearently it convert RS232 to
    USB and vice versa.
    Would it possible (how) to use this Micro-USB module con connect and an
    off-the shelf USB webcam to a micro controller such as ATMega or PIC?
    (I do not need high speed or high resolution images)
  2. No. Because Micro-USB module and a webcamera are both USB devices, and
    you would need a USB host.
    Vadim
  3. D Herring
    D Herring Guest
    Take a look at the CMUcam, it already outputs serial and may fit your needs.
    http://www.cs.cmu.edu/~cmucam/
    I've not used this product, but it resembles some designed-in-house
    camera boards I've used that worked rather nicely.
    Later,
    Daniel
  4. Wim Ton
    Wim Ton Guest
    The STV0680B chip from ST that is used in numerous cheapo webcams has an
    RS232 interface, although not for tethered video. You may have to dismantle
    a webcam and add a RS232 driver.
    Wim
