C
[email protected]
I'd like to know if the maximum power dissipation is linear with the
resistance when using a potentiometer?
For instance, I use a 0.25 W potentiometer of 1k Ohm and I set its
resistance to 500 Ohm.
Between the two contacts where the resistance is 500 Ohm, will it be
able to dissipate 0.25 W or only 0.125 W ( (500/1000)*0.25 ) ?
If so, then to each potentiometer would correspond a certain current
limit .
Have you an idea ?
Thanks for your help,
Cédric
limit .
Have you an idea ?
Cédric
