Calculating Tilt from Accelerometer
Discussion in 'Electronic Basics' started by llienossor, Jan 27, 2005.
  1. llienossor
    llienossor Guest
    I'm using a ADXL311 acceleromoter as a Tilt Sensor. The equations
    given to calculate the tilt on the x axis or Pitch is ASIN(Ax/1g) and
    the tilt on the y axis or Roll is ASIN(Ay/1g). g is acceleration due
    to gravity, Ax & Ay are the amplitudes of the analog voltages from x
    and y outputs. But I do not know what the A (presumabely amplitude of
    some sort) before SIN represents.
    If anyone has any ideas I would be very grateful.
    Thanks.
    llienossor
  2. Gareth
    Gareth Guest
    ASIN means inverse sine, or arc sine, NOT A*SIN
    e.g. SIN(angle) = Ay/1g
    Therefore :-
    angle = ASIN(Ay/1g)
