Calculating gain of an OPAMP
Discussion in 'General Electronics Discussion' started by Govardhan, Dec 12, 2013.
  1. Govardhan
    Govardhan
    9
    Oct 1, 2013
  2. Harald Kapp
    11,305
    2,588
    The gain-bandwidth product assumes a linear decrease in gain with frequency.. Basically the term gain*bandwidth is constant. So for a high gain you have a low bandwidth and vice versa. Details are here.
  3. Govardhan
    Govardhan
    9
    Oct 1, 2013
    Thanks and now I calculated the gain needed for my OPAMP
    MCP6002 has Gain Bandwidth Product of 1 MHz
    And I'm using the MCP6002 in the noninverting mode as here http://img853.imageshack.us/img853/3717/2jpp.jpgfor LP filter for a cutoff frequency of 2.3Hz and I'm using a gain of 101 (1+R3/R2=1+680k/6.8K=101).
    If want a gain of 200 with the frequency of the signal lie between 0.5 to 3Hz=2.5Hz bandwidth(required).
    BW=GBW/gain
    2.5Hz=1MHz/gain=>gain=400000
    Can I use R2=3.4K so that 1+R3/R2=201.Is it ok for this OPAMP to use a gain of 201.
    I guess its nearly simialr for the OPA378 which has bandwidth of 900Khz.
  4. BobK
    7,682
    1,688
    The word bandwidth here is misleading, it is not the range of frequencies as you have assumed in your calculation, but the upper limit of the frequencies that you need to amplify. In any case, at 3.5Hz you are not going to have any problems with any opamp.
  5. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    Here is an example of how to use the GBW product. Suppose there is a simple inverting amplifier with a gain of 20 dB (Rf/Ri=10) and the op amp has a GBW as shown. The inverting amplifier will maintain its 20 dB gain out to the corner frequency of 100 KHz. This is an approximation because the 20 dB gain will begin to fall off somewhat before the input frequency reaches the corner.
    [​IMG]
  6. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    You don't mention if the input is sine wave or square wave or some other wave. Op-amps are specked for sine wave inputs generally. If you are using a square wave then even a 1Hz wave with 100ns rise time will give a fast op-amp problems if the input is of a high level.
    Adam
