jdhar
Using standard RMC NMEA strings from a GPS unit, I'm trying to figure
out the best way to calculate distance traveled over time. The two
methods I have are:
- Use lat/long. coordinates and calculate distance using Haversine
method (or similar) each sample, and keep a running total of distance
traveled
- Use velocity each sample, and multiply by sample interval to get
distance traveled during that interval
I have done some basic tests, and these two methods work out to be
"almost" the same, but not quite... I don't know enough about the
underlying GPS design to determine how lat/long vs. how speed are
determined. Any comments on which method may be more accurate? (or are
they both equally inaccurate).
What is interesting however, is when going under a bridge structure,
the velocity readings become distorted (there is a jump and then a
dip). The lat/long readings don't seem to suffer from this same issue
however. Does anyone know why this is??
methods I have are:
traveled
