P
Paul
I'm trying to write a small program to design basic Schottky diodes.
I'm using the following equation to calculate the current produced by
a small applied voltage, far below Vt -->
I = A * Aast * T^2 * exp(-barrier/Vt) * exp(V/(n*Vt) - 1)
where barrier is the barrier height, A is the contact area, T is temp
in kelvin, Vt is thermal voltage, V is applied voltage, n is ideality
constant, and Aast is the Richardson constant -->
A = 4 * PI * q * m * k^2 / h^3
where m is the effective electron mass.
Everything seems fine except for my barrier height function, which is
if(ntype) {
barrier = F - Eea;
} else {
barrier = Eg - F + Eea;
Obviously something's missing, because there's no dopant density in
the equations. An increase in dopant density will increase the
current. I'm thinking my barrier height equation is overly simplified.
Obviously the barrier height changes with dopant density. Does anyone
have the equation(s)? I'd appreciated it.
Regards,
Paul
if(ntype) {
barrier = F - Eea;
} else {
Regards,
Paul
