Calculate Shunt Resistance
Discussion in 'Electronics Homework Help' started by inlineskater, Jun 16, 2012.
  1. inlineskater
    inlineskater
    13
    Jun 15, 2012
    Question:
    To extend the range of a 0-8.4 mA, 46.3 ohm DC ammeter, what size of shunt resistor should be used to obtain a 92 mA range?
    Using the following formula:
    Ish/Im = Rm/Rsh
    Rsh = shunt resistance
    Rm = meter resistance
    Ish = shunt current
    Im = meter current
    Rsh = (46.3 ohms) (8.4 x 10^-3) / 83.6 x 10^-3
    = 3.8892 x 10^-1 / 83.6 x 10^-3
    = 4.65 ohms
    Could of I calculated this differently. Looking this it seems correct.
  2. john monks
    john monks
    693
    3
    Mar 9, 2012
    Yes. You can calculate the voltage needed for full scale meter deflection based on the current and resistance of the meter. With the current of the meter you can calculate the value of the current in the shunt resistance. Now you have the voltage and the current of the shunt resistor and now you can calculate the resistance of the shunt resistor.
