C
CatMan
I have been trying to program my Aux 1 output to follow the panel's
Armed state. I using the DL900 software I have Aux 1 set to type 21 and
the timer set to 0. According to the docs this should cause the Aux 1
output to follow the Armed state fo the panel. Of course this doesn't work.
I also tried the latched and not latched settings and received the same
results with both. Now, on my panel there is a screw terminal strip
where the power, bell, wireless, keypad, and internal wired zones
connect to.
On the bottom of the terminal strip are five screws labeled:
Aux 2 C
Aux 2 NO
Common
Aux 1 NO
Aux 1 C
I have 12VDC on all of them referenced to the Common except for the Aux
1 NO. It is 0 Volts regardless of the panel’s armed state or of the
‘Latched’ selection in the configuration.
Maybe someone will chime in here that knows how to configure these Aux
outputs. If you look in the docs for the panel I can see a lot of
possibilities with the Aux outputs.
Thank you again for your help!
connect to.
Aux 2 C
Aux 2 NO
Common
Aux 1 NO
Aux 1 C
