CAD tools compatibility ?
Discussion in 'CAD' started by Robert Lacoste, Feb 23, 2006.
  1. Hi,
    We are looking for a new CAD system, mainly for the schematic phase as our
    routing is 99% subcontracted. Our subcontractors are using mid to high range
    products (PADS, Protel or CADSTAR). So the question : Do you know if these
    tools are able to import a schematic designed with a lower cost CAD tool
    (say Eagle or Proteus/Isis for example) ? I guess that the netlist could be
    imported but I would like to know if the schematic itself can be imported
    too.
    Many thanks for your advices,
    Robert
  2. Ian Bell
    Ian Bell Guest
    Try Kicad. It can export netlists in a variety of formats.
    http://www.lis.inpg.fr/realise_au_lis/kicad/index.html
    Ian
  3. Ian Bell
    Ian Bell Guest
    I see. Not sure if this is possible at all.
    Ian
  4. Andy Peters
    Andy Peters Guest
    It's one thing to export a netlist from a schematic program.
    It's another thing to ensure that the layout tool can deal with not
    only the netlist, but also the component packages. Your schematic
    program needs to work with the same libraries as the layout tool. When
    you place an OP275 symbol on the schematic, somehow that symbol must
    tell the layout program that it needs to use the SOIC-8 package instead
    of the DIP-8.
    Basically, you'll have to use the schematic capture program that goes
    with your contractor's layout program. If they use PADS, you'll need
    PADS. If they use DXP, you need DXP. If they use PCAD, you need PCAD.
    Equally as important, you'll need to use their libraries, or at the
    least you'll have to create your own library that you'll share with
    them.
    -a
  5. Joel Kolstad
    Joel Kolstad Guest
    This isn't generally true. I'd agree that it's often easiest to keep
    everything the same -- and EDA vendors seem to go to some lengths to try to
    make people do it so that they capture both sales! -- but many PCB packages
    will accept netlists from a handful of the popular schematic captre packages,
    and if not there are conversion programs available for any reasonably popular
    package.
    From what I've seen, people who do PCB layout for a living have all their own
    libraries anyway and will use them by default unless otherwise instructed.
  6. JeffM
    JeffM Guest
    Our subcontractors are using mid to high range products
    I can't image an affordable 100%-correct layout-import solution.
    Protection of proprietary formats and all that.
    (See JT's comment in the following thread.)
    A previous thread on interoperability:
    http://groups.google.com/group/sci....d-party-*+turf-battle+Pulsonix-*-*-*-*-*-EDIF
  7. Leon
    Leon Guest
    FWIW, Pulsonix imports schematic, PCB and library files from:
    P-CAD (*.PDF)
    Cadstar Schematics (*.CSA)
    PADS Logic (*.NET)
    P-CAD (*.PDF)
    Accel EDA (*.NET)
    UltiCAP (*.SCH)
    Protel (*.ASC)
    OrCAD (*.EDF)
    Eagle SCM (*.EIS)
    Leon
  8. Paul Burke
    Paul Burke Guest
    Doesn't it import Easy PC then?
    Paul Burke
  9. Leon
    Leon Guest
    Of course it does! I missed it when copying the text.
    Leon
  10. Chuck Harris
    Chuck Harris Guest
    Aren't OrCAD EDF (EDIF)files netlist only?
    On the old SDT/PCB 386+ stuff, OrCAD schematics are .SCH,
    and OrCAD layout are .PCB
  11. Yes, Leon is just copying something.
    lEON, you had better indicate what files/formats are what or you are
    seriously misleading these guys. I don't see one library format that I
    recognize despite Leon's comments.
    There are several formats in there that are simply netlists (i.e. PADs
    *.net & Accel *.net), not the schematics nor PCB files. Next you have the
    problem that most nobody saves their files in some of those formats (i.e.
    ascii, Protel *.ASC), so down the road you may not be able to readily deal
    with them again unless you have some friend with the tools to correctly read
    them and write the acceptable format/version files back out to an ascii
    file.
    Besides the basic information Leon has offered, there is surely
    limitations on the actual file versions that it can import. In some cases
    they may be well out of date versions. Don't be sure it will import any
    current specific format unless the software supplier will guarantee you.
    Then get ready to deal with the limitations of the compatibility upon
    importing. This is true of even the best imports because most packages have
    features or details which are not supported nor correctly converted on
    import.
    From what I have seen in over 20 years is that almost no package imports
    or converts schematic files, it is just not worth the development time. A
    schematic can be redrawn in a couple of days once you know your new tool.
    PCBs do have converters because that can save you weeks if not months of
    time to redevelop the PCB. Then you have to confirm that it is valid and the
    same as the original, all big costs.
  12. Leon
    Leon Guest
    Those were schematic ASCII formats. It will also import the same PCB
    design formats. I've only used the schematic facility on a few
    occasions, but it worked very well. It will also export EDIF
    schematics.
    Here is the Help entry for Protel files:
    "Protel PCB and Schematic designs and Schematic libraries in ASCII
    format. Protel PCB footprint libraries can be opened in their Binary
    library format.- Versions - Protel 98, Protel 99, Protel 99 SE and
    Protel DXP (2002). (Protel DOS and Protel V2.x and 3.x formats are not
    supported. Please contact your local sales office to check for
    alternative solutions.)
    Design types supported are for: Schematics and PCB
    Library types supported are for: Schematic Symbols and PCB Footprints,
    and Parts libraries"
    Pulsonix has all the major packages, and have imported native format
    files for me to one of them on a couple of occasions and saved them for
    me as ASCII.
    Leon
  13. Hal Murray
    Hal Murray Guest
    One data point...
    Several years ago, I did the schematics for a board and we decided
    to have an outside company do the layout. They could read netlists
    from our CAD package.
    When we were talking to them to setup the deal, the question of
    package libraries came up. I handed the guy a stack of printouts
    of the package footprints from the data sheets. Smile. Next topic.
    Their library had everything we needed. They just needed to know
    which part to use. No big deal.
  14. Lukas Louw
    Lukas Louw Guest
    Brad,
    I've had good results opening PCAD/Accel schematics, PCB files and libraries
    with a Pulsonix demo. I was pretty impressed - some text rotation and
    attributes were not quite correct, but that was about it.
    Lukas
  15. Leon,
    Okay I stand corrected with regards to Pulsonix, I was speaking from my past
    experiences with numerous packages and commenting on your list of file
    extensions.
  16. Joel Kolstad
    Joel Kolstad Guest
    FYI, Pulsonix can also save to ORCAD schematic format, although at the moment
    the feature is kinda in a "beta" stage where it doesn't work completely
    correctly. I expect they'll improve this feature in the future...
  17. JeffM
    JeffM Guest
    They could read netlists from our CAD package.
    Without the names of the packages, your post is worthless.
  18. Ken Smith
    Ken Smith Guest
    This is basically false.
    I use the old Orcad for DOS and it makes Pads2K netlists complete with
    correct package information. I doubt that there are any serious CAD
    programs that can't make a net list that has the needed package
    information in it.
  19. Ken Smith
    Ken Smith Guest
    That has been my experience with contract layout houses too. They will
    take input in nearly any reasonable form. If they've been in business for
    any time, chances are they have a large library of netlist conversion
    programs. Even today, they will likely have people on staff that can hand
    create a netlist from a paper schematic.
    You should, however, expect to pay for everything they have to do to make
    your PCB.
