Cable box + cable feed
Discussion in 'Electronic Basics' started by reqluq, Jan 12, 2008.
  1. reqluq
    reqluq Guest
    Hi I've been trying to send my cable box to chan 3 which works; and then get
    the other channels 05 to 55 to be able to be seen also. I use a splitter to
    split the cable signal: one goes to the cable box and other to the mixer.
    Then the feed from the box goes to the other side of the mixer.. but when I
    scan, the tv only scans chan 3..what do I need to make this happen?
    thnks
    req
  2. AJ
    AJ Guest
    Are you connecting the cable through a splitter then to the tele and cable
    box???
    If so then select the rf input connected directly to the tv from the
    splitter and programme the channels, selecting cable mode on your tele. That
    way, using the tv remote you can select the memorized channels directly.
  3. reqluq
    reqluq Guest
    If you read my post it says this:
    "I use a splitter to split the cable signal: one goes to the cable box and
    other to
    the mixer. Then the feed from the box goes to the other side of the mixer.."
    No only one..That's why I would like to use a mixer/splitter to feed the tv
    with the cable box channels on one side and the rest of the regular cable
    channels channels on the other, so, when I select chan 3 on tv, I get the
    cable box channel and then I can select the other channels from there on up
    on the tv...should I be able to do this? I have to do it this way because I
    have a number of tvs hooked up.
    so the box needs to go into a splitter and the cable feed also then out to
    the tvs...The splitter doesn't seem to be doing the trick.
    thanks
    req.
    the cable
  4. Sjouke Burry
    Sjouke Burry Guest
    You are not using the splitter as a splitter, but as an adder, this will
    probably cause intermodulation between stations, and cause all sorts of
    mayhem, the cable signals will get into the box modulator and cause
    trouble.
  5. reqluq
    reqluq Guest
    Oh my my my...listen; I bought a splitter AND something called a mixer: a
    CS-101UV with a power pass Hf-UV 5.80MHz on one side and SAT-1F 950.2050 on
    the other side, the one by itself is 5.2050MHz.Now I need to know if that
    should work for my purpose or do I need something else. I need to send what
    is on chan 3 down the same line as what's on 5 to 55 so when you put chan 3
    on the tv you see the cable box and when you go to chan 6 or what ever you
    see what's there, without using an A/B switch. Can this be done? If so tell
    me what I need to make it work so I don't have to send two cables to every
    tv..
    Thanks again
    req
